Originally wanted to go with 2 15's in a trunk baffle but 12's would be easier to fit and the cone area of 3 12's is almost as much as 2 15's.
Anyway the Skar SDR 12's are on sale right now and that would help the budget but just wanted so opinions. 3 12's for under $300 is pretty appealing right now especially since the car restoration itself has been so expensive.
Car is a 1967 Firebird.
Thought's, opinions?
- 12-inch Dual 2 Ohm Voice Coil Configuration
- Peak Power: 1,200 Watts
- RMS Power: 600 Watts
- Competition Grade Pressed Paper Cone
- High Roll Foam Surround
- Advanced Air Flow Cooling System
- 2.5" High Temperature Copper Voice Coil
- Motor Weight: 97 oz
- Frequency Response: 22 - 300 Hz
- Sensitivity: 84.7 dB
- Fs: 32 Hz
- Re: Dual 2 Ω
- Qms: 6.76
- Qes: 0.58
- Qts: 0.53
- Mms: 249.4 gr
- Nref: 0.185%
- Cms: 0.11 mm/N
- Bl: 16.67 n/a
- Vas: 36.2 L
- Sd: 471.4 cm²
- Xmax: 13.5 mm
