1 - 20 of 81 Posts
So im curious what you guys can come up with for different gear selection for different budgets. Id like to see if any drivers are common.
This isnt a build for me or for anyone else. This is just for fun.
So rules. 3 way front stage.
Under 2in(mounted) tweeter
Between 2-4in midrange.
6-8 midbass. (Most stock cars)
Budgets are for drivers only.
Budgets are
$100
$300
$500
$700.
Those, to me are the most common and averaged prices you see for most people asking for advice on drivers on Diyma.
Go!
I've got a set of vintage MB Quarts 3-way set still new in the box (reference series) with their optional Musicomp 3-way crossover that I could sell if anyone is interested.
I'll play... Here are my suggestions:
Midbass:
JL ZR800's - $440 / pair on eBay
Midrange:
Scanspeak Discovery 10F/8414G-10 4" Full Range - $129.80 / pair @ Madisound
Tweeter:
Vifa XT25SC90-04 Ring Radiator Tweeter - $43.80 / Pair @ Madisound
Total: $613.60 and one hell of a great sounding system.
Midbass:
Midrange:
Tweeter:
Mean midbass. Smooth but not super detailed tweets and mids I havnt heard. Tis a start.
The Jl's are supposed to be really powerful. I kinda feel like they cant be used without a shiton of deadening. Ive seen outer door panel flex from them. Thats gotta wreck havoc on FR
Its easy to do expensive buy can you pull one together for under $100. Try it..
Sent from my SGH-T999 using Tapatalk
I'll bite as well. Since there was no mention of mounting depth, I'm listing my favorite detailed mid. All madisound speaker 3-way SB Acoustic set.
Tweeters: SB29RDCN-C000-4 $57.20/ea
Mid: SB12MNRX25-04 $51.20/ea
Woofer: SB17NRXC35-4 $57.85/ea
Total cost: $332.50
Total cost: $332.50
35hz fs on the woofer. Excellent. Is it a great MB driver to you?
It's a detailed driver set. You will not compete for midbass SPL with it, but you will notice each string of the bass being plucked. Also the entire 3-way is 60 watts/driver.
If you can fit that midrange
Como se huh?! In the passband that these would be running in, say 5KHz & above, you're not going to find anything better for 10x the cash if they're properly installed and tuned.
Now, the ZR800's are monsters, but I've deadened my car quite well. The only driver I'd even consider changing them for would be the Scan 18WU's, and I'd still likely use the ZR's. I've got an IDMAX 15 coming on Tuesday and I can't wait to see how well they blend together.:cool:
If you haven't listened to the 10f's, you really should. They're fantastic. Previous mids I've tried: HAT L3SE, Illusion C3 & C3CX, Morel CDM-880, and the AP NZ3's.
Discussion Starter #12
I have heard the neo xt25 suffer at higher volumes.
Ill be putting in a tm65, hertz hl70, the xt25 soon. Should be a solid combo
I am 2/3 of the way towards a $100-$200 set...
Dayton ND16FA-6 tweeters - $10 each
Dayton RS75-4 mids - $22 each
I would like to try with the Dayton RS180 but they won't fit, that would put the total at about $160. Maybe Silver Flutes that put's the total at I believe just over $120 for a 3 way.
$200 All-Tymphany setup ~ SLS 6.5 ($120/pr), TC-9 ($30/pr), & XT-25 ($36/pr)
Below a certain price point, choosing a 3 way setup instead of a 2 way setup starts to be more trouble than it's worth. You have to make such a compromise with driver quality to be able to buy 6 instead of 4 that I think that you'll end up worse off. That said, here's my $100 attempt:
Midbass: Dayton DC160-4, $24.63/ea
Midrange: Fountek FE85, $12.80/ea
Tweeter: Dayton ND16FA-6, $9.64/ea
This total comes in at $94.14 from Parts Express. If you have the room for a shieled 3" driver, you can substitute the Fountek for a Hivi B3N, which leaves you just enough money for a Dayton DA-175 7" woofer instead of the DC160. The DA-175 is an 8 ohm driver, but has great low end and good excursion. I actually use one as a subwoofer in my dining room.
I would probably sneak ever so slightly over the $100 limit ($102.04 to be exact) and use the Dayton DA-175, Fountek FE85 and Dayton ND16FA.
Wave Shepherd
I recently built a bookshelf 3-way with purpose-made passive crossovers using the following found at Parts-Express. I can give you the crossover schematic if you're interested. I'm really astonished at how good they sound for the money I spent building them:
Dayton Audio ND25FA-4 1" Soft Dome Neodymium Tweeter ($15)
Dayton Audio RS52AN-8 2" Dome Midrange ($41)
Dayton Audio DCS165-4 6-1/2" Classic Subwoofer 4 Ohm ($43)
Crossover frequencies I used are: 500hz and 3.0khz
Good luck with your project!
Hi-Vi LK6.5 6.5" Woven Kevlar Cone Woofer $36.50 Each
Eton Symphony 3" Midrange 3-400/A8/25 MG $169.00 Pair
Tymphany XT25SC90-04 1" Dual Ring Radiator Tweeter $18.00 Each
$278, mid-woofs and mids from the Madisound Specials page. Tweeters from Parts-Express.
I put most of the money in the midrange as that's my sweet spot and IMO the Eton mids are an excellent deal at that price...I've heard the mids and the tweeters (separately), both very nice. The mid-woof looks to be a sweet deal at $36.50. For under $300 this could be an excellent system with careful DSP work.
D.
Discussion Starter #19
D.
The power handling on yhr hi-vi is only 40rms..
Accomplished this a few years back and still keep the drivers shelved because they're that good.
Jamo 24394 6.5" $9 each (grabbed 4, 2 for backup). Check the plots & test review on zaph.....
Peerless TC9FD 3.5" $13 each, but got them on sale for $10 each
Dayton ND20FA-6 3/4" tweets back when they were $10 or so each.
All great performing drivers with a very usable bandwidth. Total $60 plus shipping, but actual $80 if you want to count the spare mids.
1 - 20 of 81 Posts
