1201 - 1208 of 1208 Posts
Is the Rockford 3sixty3 better than the Rockford DSR1?I like the fact I could make adjustments on my iPad with the DSR1 but I’m not clear on which is better and I already own a 3sixty.3,any advice would be great,thanks
Hello, I want to know where I can repair 3 3Sixty.3 that are damaged, the red led keep on. The first I destroyed it during the installation, the second I bought it damaged to try to repair it and the third one died tonight while I recharged the battery of my car. I also wanted to know how to protect this equipment, try to isolate it to avoid high voltages. Thanks in advance.
Sorry, I'm not sure where you would have one repaired or replaced in the Dominican Republic.
In the U.S., contact Rockford-Fosgate directly. I don't believe that they are REPAIRING these any more. However, they will REPLACE the entire Circuit Board with a new one for $245 USD. I'm sure that just the shipping cost would be prohibitive though. :(
At this point, the 3Sixty.3 is very old and is not supported. I would seriously not invest any more time or money in these units. You might ask RF for a "trade in/trade up" to the newer RF DSR1 which you can tune or adjust from a smartphone/tablet app if that unit will do what you need it to do.
Good luck.
Good luck.
Thank you for the information. I just bought another unit last night on Ebay (my setup is based on the 3Sixty.3) but this RF DSR1 unit that you mention is similar in functions to 3Sixty.3? The DSR1 will works in an Acura TL 2005?
What's your current setup using 3SIXTY.3.
Sent from my HTC U11 using Tapatalk
In the U.S., contact Rockford-Fosgate directly. I don't believe that they are REPAIRING these any more. However, they will REPLACE the entire Circuit Board with a new one for $245 USD. I'm sure that just the shipping cost would be prohibitive though. <img src="http://www.diymobileaudio.com/forum/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
Good luck.
They're still technically supported. Not sure what makes you think otherwise. Mine just died on Thursday for no reason.
I'm afraid mine may be going out now as well. I've gotten used to the quirks and required order of steps for operation. Ive ran it with High, RCA and now Optical inputs. Honestly, I've had zero issues with it until now.
However, over the past few days, it won't save my complete settings...even after making sure to close the software before removing the usb cable. I should clarify that most xover settings are retained, only the sub "invert" feature is unchecked every time I open the program. Haven't noticed any other glitches as it will keep any other changes I make, which is odd and makes me think it's something random.
The second, possible issue is the smeared stereo imaging via optical. Using RCA inputs, L and R check tracks are perfect. When using SPDIF, it's all over the place. This is after proper channel routing too.I know the 360.3 doesn't accept full 5.1 encoding via optical but should easily handle seperated PCM 2.0 data. And I say possible issue as this one could be caused by my CarPC as I've read the newest Windows 10 update has messed up audio output for some.
