Hello
I have a NVX VAD11005, it is a 5 Channel Amplifier. I was setting the gains the the speaker outputs with a Digital Multi-meter. I was setting the gain for the Front Channels, I was first doing the Front Left out puts, I set the voltage to 15.00 watts, I check the Front Rights and they are at 13.00 Volts, and for the Rears the voltage was higher in the Right. For this amplifier you can only set the gains for the front and the rear Channels not each individual speaker channel.
Is this normal? or do I just have a cheap amp and they mostly like that? Or maybe my RC cables are just sending different single voltages?
