1 - 12 of 12 Posts
just found a guy who stocks avi stuff (that supposedly guys rave over on diyaudio)
just wondeirng if any of you guys have heard thse two speakers ??
the audax HM100C0 ($50 each) 8 ohm
http://www.partsexpress.com/pdf/296-053.pdf
response graph looks cool
it drop from 90+db to about 700hz then it drops down to 87 db dont get that???
or the avi MXD-100 ($100 each) 4 ohm 12.6 oz magnet WOW lol
(and not like I need it, but sposedly the lxd-100 is better on the low end for better midbass??)
specs page
http://www.avisound.com/mid_devices/mxd100.htm#
and fyi guys he stocks the 2" FRM-70 also :) if they werent so costly id run 4 of em (90 each)
spec sheet
http://www.avisound.com/mid_devices/frm70.htm#
and they come in 4 ohm and 8 ohm SWEET
ah, so you have new speakers to test?
I'd like to send you my Mb quarts, but I'm absolutely broke. perhaps in the future. If I dont sell them. I'd like to see how the tests compare to how they sound. although subs are also on my wish lists to see tested. a W7 and ED subs especially.
hey would you please tell me if a TC2+ subs sounds as good as a W7.
note: I'll likely share your statement with others. not sure If you want to be responsible for that.
also you can find some info on a 4" audax driver and tweeter at
http://zaphaudio.com/audio-speaker14.html
comparing the companies posted specs and the tested ones. their a bit different. sensitivity and response are different, by a bit after all is said and done.
<snip>
Measurement error. :) I know a few people who bought this driver (or the HM130C0, which measures similarly) thinking that it would simplify the crossover design by self-compensating for baffle step in a 6-7" wide minimonitor enclosure, and found that to not at all be the case. Audax also made a HM100Z0, and I'm a big fan of their Aerogel (HD-A) cone. I don't know if anyone still has any in stock, though. Any HM-series Audax driver has a good motor, though not one up to Excel standards. They were also among the first driver-makers to produce modern baskets, with under-spider ventilation.
One thing that may be an issue for you is that the Audax drivers are all discontinued. That is, when current stocks dry up, they're gone. That said, the Aerogel ("HD-A") drivers produce some extremely compelling midrange. Outstanding detail with a electrostatic-like quickness to transients that's lacking in some of the modern designs, including the Seas Excels.
That's the kind of thing that annoys me about the car-fi industry. 150Hz extension my ass. OK, it has roughly twice the cone area of the Aura Whisper? However, it also has all of ONE-THIRTIETH the xmax! If they've designed it to allow crossovers as low as 150Hz, as implied in their specifications, then what that REALLY means is that they designed so much DYNAMIC COMPRESSION into the driver that you can forget about anything resembling actual music to emerge from it. That would be sad, because AVI made one of only three explicitly car-fi mains sets I've ever heard that were remotely worth a damn, a coincident/dual-concentric driver with a fiberglass (IIRC) cone. (The other two were the KEF KAR System 160Q's, using their Uni-Q coincident configuration, that have homes in the doors of my Citroën, and amazingly enough a ~$100 6.5 coax from JBL - GTO622 I think it was, Bob Johann competed with them for a while and turned me on to them - that not coincidentally used the same type of tweeter mounting as the AVI, KEF KAR, and the currently available Seas H1144/H1333.)
1 - 12 of 12 Posts
