rebar said:
Captainobvious said:
What makes you think you need 4ohm speakers?
Because.........
Originally Posted by
rebar
compared to the vintage 4 ohm MB quarts on the front channels, wouldn't equal the volume on my PPI4200...
In fact, I need more volume from the home speakers because they would be farther away.. So 8 ohm wont fly.
Is this a cargo van or a industrial van with an open back cabin?
Cargo Van with paneling, bench seat and bed on top of the trucktuba's
Why do you feel you need the same volume in the rear?
Really?
Lets say Im tailgating.. Why would I want my front MB quarts about to blow up, when Im trying to get volume from the home speakers?
And I doubt my PPI would like 4 ohm components on two channels , and 8 ohm home
speakers on the other two channels.
Look, you're asking the questions and I'm taking the time to try to assist you. You haven't been overly specific about what you're trying to do and in what application/setting so the questions need to be asked. That's how this works.
You are correct about speakers farther away needing more output to sound as loud as speakers closer to you. But first, lets start with the 4ohm speaker thing at the top. Impedance doesn't equal volume. What matters is the sensitivity of the speakers being connected. If you connect an 8ohm speaker with 6db higher efficiency than the 4ohm speakers you connected, it doesn't matter that your amplifier is producing more power into the 4ohm speakers- they will still play at a lower volume. Efficiency is even more crucial if you have limited or lower power amplifiers and desire a higher output volume.
Amplifiers which have stable output at 4ohms will have no problems using speakers rated at 8ohms. In fact, they will draw less power from the amplifier allowing it to run cooler, so if anything- it's
better for the amplifier, not worse. Many, many people on this forum (myself included) either use or have used 8ohm drivers in their vehicles with great success. In fact, I'd argue that there is a far larger pool of excellent choices in 8ohm impedance than in 4ohm.
Have a quick read here to understand better about 4ohm vs 8ohm:
http://www.diymobileaudio.com/forum...d-our-members/31-real-deal-8-ohm-drivers.html
You mentioned that you want the front and rear speakers to be level matched. You can easily achieve this right from your amplifier (gain) or head unit by adjusting the output level to those channels (You could simply use your Front/Rear fader to adjust that balance.)
Since you're looking at bookshelf and/or tower speakers, I'm assuming that leads to your point about tailgating. Will the speakers be a permanent fixture in the vehicle (like mounted to a shelf inside the cargo van) or will you have a length of wire and set them up outside the vehicle? I ask because you may simply want to look for some higher efficiency small pro audio cabinets. They can play plenty loud and not need much power to do it.
