1 - 9 of 9 Posts
unfortunately you can't just copy someone else's EQ settings and expect it to sound good in your vehicle. It is completely dependent on your equipment, interior of your vehicle, power, crossovers, slope and everything else you can think of.
What are the 7 frequencies and how are they set currently? Some description of your setup/equipment would help.
60Hz=0dB, 150Hz=-2dB, 400Hz=-6dB, 1kHz=-4dB, 2.4kHz=-2dB, 6Khz=0dB, 16Khz=2dB.
blaupunkt velocity v2100 amp, with jbl sub amp, pioneer 6x9 rear speaker, mb quart qm130 front with rtc19 tweeter, HU is an old alpine stereo with a built in dsp (not used) and graphic EQ.
all on a 2000 Toyota camry. BTW the tweeters are mounted on the upper piece (where the side mirrors are), not on the dash.
60Hz=0dB, 150Hz= -4dB, 400Hz= -1dB, 1kHz= -2dB, 2.4kHz= -5dB, 6Khz= -4dB, 16Khz= 0dB.
This should sound different.
yup it sounds different enough, I dunno why but it really sounds a bit nice.
Now cut 16khz -2 to -4 and raise 1khz to -1. Play around a bit see what sounds best.
1 - 9 of 9 Posts
