1 - 6 of 6 Posts
· Registered
Looking for anyone who has had good luck with various combinations of 8"subs and pre-fabricated boxes...
I don't have the ability to build a box right now and I want to upgrade my 6.5" sub.
I prefer a ported box and will be looking for a sub that can handle at least 600watts RMS.
I am currently running a Mmats M600.1D amp fed by the stock head unit through an lc2ipro.
I am in a nissan frontier, so space is kind of an issue.
Any suggestions?
· Registered
· Registered
2014 Toyota Avalon Limited
The biggest issue with prefab ported boxes is they’re tuned way too high (about 40Hz)… unless you like that type of sound. Do you have the ability to cut a hole for some PVC pipe perhaps? I’ve had very good luck in the past getting a slightly larger sealed box, then cutting some holes for some PVC pipe to tune it to about 30-32Hz.
By the looks of the box mentioned above you could cut a hole or 2 for some 3” or 4” PVC with a hole saw on the long “leg” side.
· Registered
SAAB 9-5 Aero / 2008 Siverado / GMC Canyon
I flip my seat in my crew silverado as well. I am currently running a 12" in a sealed… and have also run a 10 inch in the same location… One cube sealed. If either of those set ups interest you I could help you out
1 - 6 of 6 Posts
