Hi there I’m new here and this is my first post but I am a long time lurker. I’m not new to car audio but I haven’t done much in recent years. I use to be into SPL stuff but now I’m trying to get into more sound quality type stuff these days. So I would like to start my first sound quality build. First off the vehicle in question is a 1986 Toyota 4Runner turbo. This vehicle is going to be a full overland build and restoration. I intend to live out of the vehicle for months at a time while traveling the country, which means I am going to have it packed full of gear and electronics smashed in every corner. So space is of the essence. I listen to mainly rock and rap music but I do listen to just about anything.
The vehicle originally came with 2 front 4 inch speakers mounted in the lower dash and 2 6.5 powered rear speakers mounted just behind the rear seats on the sides. Pictures of the interior included.
My plan is that I’m thinking on doing a custom install on the front 2 doors of a pair of 2 way components mounted with mid bass in the lower front of the panel and the tweeter mounted in the upper front of the panel. A pair of 2 way components or mid bass where the factory rear speakers are. 1 subwoofer mounted into one of the rear quarter panels. A 4 channel and mono amp or a 5 channel amp mounted behind the quarter panel plastic on the opposite side of the sub.
What I have already for equipment
*Pioneer DMH-C5500NEX
This is the one with the remote display because the radio is in a worth less place down near the floor from the factory. I needed the display higher so that’s no problem there.
*digital designs SL-710. I had from a previous build. I intended on mounting it in a custom box in the quarter panel like what is done in these pictures.
*rockford fosgate PBR500x1. I may use this to power the sub and it is compact. It’s from a previous project.
Here’s my questions.
*for front components I am thinking image dynamics IDQ 65CS. I’ve been impressed with image dynamics in the past and I need a slim set of front components. My door isn’t very deep due to the fact it was never designed to have speakers in it. Unless someone has a better components in mind?
*rear spears ? Components? Or mid bass for rear fill ? Or nothing? They are going to be mounted in the factory rear cargo area right behind the rear seats.
*which mid bass would you suggest? Or just buy a component set matching the front and just use the woofer? If so would you use the cross over that came with the set ?
*I can possibly mount the rear speakers on the sides behind the front seats, in front of the rear seats. Would mounting them there be better than than the cargo area?
*should I run the rear mid bass in box’s or just open in the quarter panel?
*sub box material? Wood or fiberglass? Or a possible combination of the two? it will be sealed and like I said it will be mounted into the rear quarter panel. Also see the one made out layers of wood in the pictures. Anyone ever tried that?
*Suggestions on a 4channel AB amp that does 150 rms at 4 ohms ? Needs to be fairly compact. It will need to be hidden with no air flow so it should probably have a fan built in.
*suggestions on 5 channel amp same thing with at least 500-800 rms sub channel at 1 ohm?
*will the pbr500x1 I have over heat if mounted with no air flow? I think it ran hot from what I remember.
*use amp cross overs or head unit ? Roughly what would you set them at?
*should I have a dsp? Space and power are fairly limited. If so what kind ? There will be no access to adjust it other than on install.
*if there were a dsp would you still use the speaker crossovers? Would you still use the cross overs or adjustments on the head unit or amps?
*batt cap or capacitor? I will be running dual batteries with a battery isolator for all the other accessories (refrigerator/lights/inverter/etc) and a big alternator.
*any other suggestions you can think of that I haven’t ?
Sorry I am aware this is allot of questions. Thanks in advance.
