1 - 20 of 67 Posts
All,
In the spirit of sharing, I'm posting my findings as I dive into the world of in-car measurement w/ a laptop & microphone data acquisition system. I hope others can benefit as I learn the ins and outs of using this tool, and I continue to move forward in that never ending quest for better sound. :D
Background/Purpose
  1. I've always wanted to better understand my car's acoustics.
  2. I already had a laptop, so buying a mic and setting up a measurement system was both inexpensive and easy.
  3. What measurable differences in frequency response will we actually see when speakers (raw drivers) are put in the "harsh" automotive environment?
  4. Does a "car-audio" specific driver really work that much better than a "home" driver in a car door?
  5. What impact does sound deadening and install effort have on the frequency response of a car door loudspeaker?
In the course of this thread, I hope to explore the answer to those questions.
Setup/Procedure
Figure 1: Measurement Setup
  • Acer "Ferrari" Laptop :D
  • M-Audio MobilePRE USB
  • Behringer ECM8000 Measurement Microphone
  • Associated connection cables
  • ARTA Software
  • My 1999 Honda Accord LX 4 Dr., Phoenix Gold XS6600 Amplifier "rear" channels driving the door speakers
  • Seas W15LY-001 loudspeakers
  • Seas Lotus Reference RW165 loudspeakers
Figure 2: Microphone Placement (those are shadows, my car isn't that dirty! :p)
  1. Hardware was set up per manufacturer's recommendations.
  2. Microphone placement per Figure 2.
  3. Sound output was input directly into the car amplifier, bypassing the processor completely. Only one channel measured at a time.
  4. Impulse response measurement (MLS), 1/3 octave smoothing.
  5. First round of measurements were done with two pairs of speakers: Seas Excel W15LY-001 and Seas Lotus Reference RW165. No modification or additions to the car door accept for the attachment of MDF mounting/spacer rings.
Measurement Data
Figure 3: Left Door, W15LY-001
Figure 4: Left Door, RW165
Figure 5: Right Door, W15LY-001
Figure 6: Right Door, RW165
Observations
  • Cone breakup is readily seen (just under 5 KHz) in the RW165 on figures 4 and 6.
  • No surprise: left and right side response are quite different, note the poor bass response on left side.
  • As expected, the magnitude of the swings in frequency response are quite astounding over the speaker's usable range when placed in a car door.
Discussion/Analysis
I exported the data from ARTA and graphed/overlaid the W15 with the RW165 so that a more direct (in door) driver-to-driver comparison could be made. The results are shown below.
Figure 7: Comparison of the the W15LY-001 to RW165, Left Door
Figure 8: Comparison of the the W15LY-001 to RW165, Right Door
Key Takeaways: (however obvious they may be)
  1. The vehicle's transfer function (environment) has far more impact on frequency response than any other variable. Differences between drivers are relatively small in comparison.
  2. Differences in driver performance (frequency response) are quite measurable. These drivers to me sound different, particularly in the midrange, and the differences in response from ~1KHz and up correlate well with my subjective evaluations.
  3. I was surprised that the lower frequency response of the two drivers didn't differ more, but there does seem to be a small measurable difference nonetheless. It's not much though, and error in accurate gain setting and in measurement repeatability renders that point completely moot.
  4. If smooth frequency response is your goal, there's no way of getting there without having separate left/right EQ, AND alot of control via parametric or NUMEROUS graphic bands.
Next Steps:
  1. Deadening/sealing the doors to see how that impacts speaker frequency response. I myself have experienced enormous subjective differences with installs in the past, and I'd now like to see how that measures.
  2. Testing ensolite and/or other treatments behind the speaker to see how they impact frequency response. (How effective they are at killing "midrange echo"?)
  3. If I'm ambitious, I may try to measure differences using clay as a door "decoupler", etc... We'll see. :D
  4. If there's something interesting you want me to look at, throw your ideas my way. :D
Enjoy!
I think if one was to search for it, they will find a tutorial that Ngyen did a while back on in-car response measuring technique. He also posted the results of my 3way setup. I think the plot showed all 3 plus sub in different colors on the same plot and then a summed curve. It was ugly.:(
Yep, for sure. Definite inspiration for what I'm now doing. Here's one of the threads:
http://www.diymobileaudio.com/forum/showthread.php?t=17
Great study, Great info. Thanks for the forethought and execution. Things like this will def. change the way one thinks of car audio.
I don't know if you tried this or not, but check to see if placing the microphone on the passenger side reverses your L/R results.
It would also be interesting to compare the off-axis response of the driver outside of your car with the response in the car to see how much is the door and how much is just the driver.
That was something I was going to do, but didn't have time. I'll check things out before I deaden the doors.
This isn't something I'm interested in pursuing. It is more difficult to set up a test like this, and much of the data provided by the manufacturers already covers this, but I do see where you're coming from...
I also thought about taking some measurements with the door open (to just test the speaker "enclosure" and not the "listening room"), but didn't carry through with that either, because in the end, that situation doesn't reflect any kind of reality.
Thanks for the feedback, Chris. I'll report more when I get the chance to take more measurements. :D
The open door idea sounds good...and place the mic about 1 meter away outside the car. That should give you a readout of the enclosure as if it were in a vacuum...well almost.
That is just such a huge difference in output below 100Hz between L and R it makes me wonder if that is what you hear when you listen.
Perhaps the seal around the driver wasn't as good on the left?
Nice post.
What happens when you play the two sides together? ;)
All hell breaks lose! :p ;)
That's definitely coming. What I wanted to do was finish deadening, EQ each side individually to flat, and then see what happens when the two sides are combined. At that point, I'm hoping the space-time continuum doesn't collapse. :D LOL....
Wow, thanks for posting this. Can't wait to get my MobilePre fired up to see how big of a mess mine is too! :(
Discussion Starter #13 (Edited)
aah ima have to head over to your place to get my car measured :D
Next meet, we can definitely do that. Better bring me some beer or something though. :D ;)
One thing I am considering is buying a (better) calibrated mic. The ECM seems to work fine, but it doesn't have a calibration curve, so there's some (unknown) absolute measurement error. For this study, it's no problem because I'm looking more for relative results. But if I want to be more serious about this in the future, a better mic is probably in order. Just FYI.
I like the MobilePre, BTW, really nice unit. I got mine off ebay for about $75 shipped, IIRC. Cool unit, and quite flexible with all of its inputs/outputs.
Powerful evidence for the need to get mids and highs away from the lower doors!
One question, though: how is the driver mounted in the door? Is it firing straight out, or is it mounted on a metal panel with the outer door panel between? I ask because the 1kHz dip could be some sort of cavity issue. I've found something similar (except ~an octave up) in the NB Miata.
I ask because I've found a Miata's.
Discussion Starter #15
These are completely stock locations. The speakers are mounted via spacer rings directly to the infacing (relative to the cabin) door metal. The door "card" (which includes an integrated plastic speaker grill) was then reinstalled. Speakers are firing out pretty much normal to the door. This is the basic, "standard" door speaker install.
Wow, big up man! Thanks a bunch for putting together this study. I look forward to the results and your observations.
Dumb question but I think a reasonable request considering it might be realistic-how about taking a couple measurements with the windows just to demostrate what happens there. Some of us like to drive with the windows down.:blush: :D
Dumb question but I think a reasonable request considering it might be realistic-how about taking a couple measurements with the windows down just to demonstrate what happens there. Some of us like to drive with the windows down.:blush: :D
Great info John, this was the fist post that ate up my "break-time" at work ealier today. I look forward for more new and revealing tests, albeit this doesn't so much pertain to installs of my nature, it's still very interesting. Glad I bought a DCX-730, wooooo! Individual Channel EQing! :D
-Fixtion
1 - 20 of 67 Posts
