O.K. first thing is that I read that if you tune your ported box above the lowest frequency you plan on pushing through it you can damage your subs.
Any truth to that? Sounds like BS to me.
I run a subsonic filter so that should be good enough right?
QUOTE: "If you pick a tuning frequency above the lowest frequency that you intend to drive into the speakers, the speaker may well be damaged due to the lack of damping. Below the tuning frequency, all of the control will depend on the speaker's suspension. If you drive the amplifier into clipping, the problem will be even worse. If you're not sure about the proper tuning frequency, use a sealed box or at the very least keep an eye on your woofers for the first few times that you drive them hard with very low notes (and for the idiots out there... DON'T put your eye on the woofers). "
Second thing is that I just bought new subs and box. I got 2 Treo TE 12's in a sub zero enclosure. The enclosure specs say it is tuned to 34hz. I have my LP filter set to about 65-70hz. I can't hear any of the higher frequency bass notes that I heard with my previous subs. All I hear is massive deep low tones. Would tuning the box higher improve this?
I went from 2 JL audio 12W6V1's in a box tuned about 45hz to the Treo's.
Everything is in the trunk of my 91 Nissan Maxima
EDIT:
Another question. How does box size affect sound? My sub manufacturer states 1.6 cu ft for a ported box, but the box I am using is a good bit smaller than that. Would that change the frequency that is dominant? What does a smaller than recommended enclosure detract from a subwoofer's sound? Can it damage a sub?
EDIT:
