1 - 19 of 19 Posts
A/D/S Mid and tweet set 641is
Condition of all items: used, sound great
2Tweeters and cups
2 Mids with grills
1 big ass crossover
Come to find out,these are from a 3 way set,was delivered with only 1 crossover!
These xovers(s) are tri-ampable and are big and beefy.
**again,only 1 crossover included.
Total Price: :125 shipped or best off,dont really know what they are worth.
Shipping Terms: :included,fedex.
i have a pdf of the manual,how do you post one?
uency response +/-3dB: 40Hz to 22kHz
tivity 2.83 volt 1m: 91dB
dance, nominal: 4 Ohms
mmended amplifier power watts RMS: 20 to150 watts per channel
nsions – woofer/midrange transducer mid-range woofer
nting depth (woofer): 2 3/8” / 60mm 2 7/16” / 63mm
all height: 2 11/16” / 69mm 2 15/16” / 79mm
all maximum diameter: 6” / 152mm 6 1/2” / 165mm
mum height above panel without grille: 1/2” / 13mm 5/8” / 16mm
mum height above panel with grille: 3/4” / 20mm 15/16” / 24mm
mum grille diameter: 6 1/2” / 166mm 7 1/8” / 181mm
ut size: 4 5/8” /118mm 4 15/16” / 125mm
nsions – tweeter transducer
dard mount height: 1 1/4” / 32mm 1 1/4” / 32mm
mount cutout diameter: 1 7/8” / 48mm 1 7/8” / 48mm
mount depth: 1” / 26mm 1” / 26mm
nsions – crossover network
h/width/height: 101/16” x 3 1/2” x 1 5/8” 259mm x 89mm x 42mm
over points: low to mid 200Hz Mid to tweeter 2.2k
e-Small specifications
air resonance (Fs): 57.2Hz 57.1Hz
rical damping (Qes): .34 .47
hanical damping (Qms): 4.87 6.00
damping (Qt): .32 .44
valent volume of compliance (Vas) cubic feet / liters: 0.26 / 7.41 0.46 / 13.0
tive cone area (Sd) in2: 14.1 18.9
er to peak linear excursion (Xmax): .16” / 4.0mm .16” / 4.0mm
to peak excursion: 1/2” / 12.7mm 3/4” / 19.0mm
coil DC resistance (Re): 3.1 3.1
coil diameter: 1” / 25.4mm 1” / 25.4mm
coil length (winding length): .45” / 11.5mm .45” / 11.5mm
a/d/s/ subscribes to the philosophy of continuous product development therefore the specifications may change
this one is pretty rare. I saw lots of 346is around but not 641. I love the drum rolls on those A/D/S, especially with Nakamichi HU. Good luck with the sale
Might have a Bud that might be interested in these. I'll keep you posted.
Hmmm? Sounds like a mix of components huh? Anything a/d/s is still good O/S gear though as long as it's fully functional. I have aquired quite a collection myself but just cant see using these. By the way, are the mid-bass 4" dia?
Discussion Starter · #8 ·
I'll measure in a few...hooked the tweeters up with some mbquart inline xovers and they sound pretty dam good!
IMO, a/d/s tweets are very easy to listen to, not harsh or over bearing at all.
By the way, I PM'd you.
Those tweeters were common across their lines. The 641 is a 3 way set, though. It looks like you're missing the 6.5" midbasses. The drivers pictured are 4"? Excellent set in the day. ADS tweets were close to the OZ tweets. The OZ tweeters beat em out in volume, but for quality and smoothness, it's hard to judge. Great buy for the price no doubt.
i would love to trade my 364is woofer and crossover for some focal 165k2p woffer and crossover, they sound good with focal tn52 tweets.
For anyone looking for some more info on this set as far as the midrange goes just search for the 344is. That is the model for the 4" compset that came with that midrange and tweet! One of my favorite 4" mids of all time! I also love the tweets due to the laid back, subtle detail, and just flat out smooth sound (flat too...but that was what a/d/s/ was all about :)
If you had the second xover for the set they would be GONE to me already! I owned that 3way set a long time ago and it still stands as one of the best 3way sets ever put together by any company in my opinion. This was the pinacle of what A/D/S/ once was! GLWS. If you can dig up the other xover let me know;)
1 - 19 of 19 Posts
