Thinning the herd ahead of a move.
1. Sinfoni Presitgio
2. Sinfoni Prestigio
3. Sinfoni Prodigio
4. Quartorigo Prodigio
5. Genesis Project 15 SN54
6. Genesis Project 15 SN15
Prestigio Specs
  • Power Supply: 11-14.4 Vcc
  • Total Armonic Distortion: 0,01 %
  • Stand-by- Current: 6 A
  • Input Sensitivity: 0.4 - 8 V
  • Input Impedance: 48 Kohm
  • Frequency Response: +/- 1 dB 10 Hz - 30 kHz
  • Output Power 4 ohm @ 12 V 65 W x 2; 2 ohm @ 12 V 120 W x 2
  • S./Noise Ratio: >100 dB
  • Dimension: 410 x 250 x 85 mm
  • Weight: 7.2 kg
Prodigio Specifications
  • Power supply: 10-14.4Vcc
  • Standby current: <2A
  • Input sensivity: 0.4-8V
  • Input impedance: 48KΩ
  • Current draw: 100A
  • Output power 4Ω @ 12/14V: 150/200Wx2
  • Output power 2Ω @ 12/14V: 250/400Wx2
  • Output power mono 4Ω @ 12V: 500Wx1
  • Output power mono 2Ω @ 12V: 800Wx1
  • Frequency response: +/-1dB 10Hz-30KHz
  • Signal/Noise ratio: <100dB
  • Dimensions (WxHxD): 410x85x250mm
  • Weight: 7.3Kg
Project 15 Specifications
Genesis Class A/G with Class A Tube Pre-stage.
Rated Power: 4 Ω: 2 x 30 W RMS
Class A mode 2 W : 2 x 15 W RMS ( This is not a misprint ! )
Typical Power: 4 Ω: 2 x 300 W RMS
Class G Mode 2 Ω : 2 x 375 W RMS
1.5Ω: 2 x 425 W RMS
Frequency response: 20Hz to 50KHz +0 -0.5dB
S/N : > 107dB
Distortion: Less than 0.1% at rated output. Typically 0.02%, second harmonic.
Input Sensitivity : 0.7 - 5.0 Volts 8.5 Volt pre-out compatible
Fuses: 2 x 40 Amps
Size: 625 x 325 x 100
Weight: 18kg
Condition
1.
Used. 10/10 Operational. 8/10 Physical Condition due to age and being used.
2. Used. 10/10 Operational. 8/10 Physical Condition due to age and being used.
3. Used. 10/10 Operational. 8/10 Physical Condition due to age and being used.
4. Used. 10/10 Operational. 6-7/10 Physical Condition due to age and being used. This unit has a few very light scratches on the top shroud and on the more serious rub marks on end plate (see pics).
5. Used. 10/10 Operational. 8/10 Physical Condition due to age and being used. This amp has high polished chassis but does not have lit glass top as some due. Amp was fully serviced and inspected in the past month.
6. Used. 10/10 Operational. 8/10 Physical Condition due to age and being used. Amp has standard non-polished chassis. Amp was fully inspected in the past 3 months.
Price:
1.
$1400 shipped to lower 48. Buyer to pay PP fees.
2. $1400 shipped to lower 48. Buyer to pay PP fees.
3. $1850 shipped to lower 48. Buyer to pay PP fees.
4. $1750 shipped to lower 48. Buyer to pay PP fees.
5. $4000 shipped to lower 48. Buyer to pay PP fees.
6. $4000 shipped to lower 48. Buyer to pay PP fees.
Disclaimer: Please don't PM me asking my best price. The price listed is what I'm willing to sell for. If you have a hookup and can get you the same item for less, you should buy that one. Scammers and low-ballers will be ignored.
All items will be very well packed. Shipping on the P15s may take a few extra days given the amount of packing that is required to ensure their safe travel.
