1 - 7 of 7 Posts
Hi there,
I have Alpine spx-177R run by the Infinity amp Ref-7541A. My HU is Alpine 9887. The problem is that the left front speaker sometimes gets silent and never makes a sound till I'd turn up the volume very high and then the speaker start to sing! If I turn it down sometimes the speaker again stops singing!!
I've replaced the RCA cable but no difference. Checked all connections too.
plz help a newbie in solving the problem since no question's going to be dumb here!
Thanks in advance.
I had this happen to me once when I had a pair of A/D/S 325is - my right tweeter wouldn't play until I turned the volume up......turns out it was bad speaker wire, after swapping crossovers, etc....
I have no passive crossover since the system is setup 3-way by cda-9887 (network).
Anyway I've checked the connections before & found no problem! Maybe it's necessary to replace some wires.
Usually a bad connector on the speaker, but can be something else even the amp.
Discussion Starter · #7 ·
An important issue is that the 2 pairs of speakers are set up through active crossover of the head unit 9887 (by network) and they're driven by one 4-channel amp so in 2-ohm. That is one pair of woofers/tweeters in 1 channel! Finally now the 2 left woofers (front & rear) have the problem. So the connection of the two is supposed to be ok unless both have week connection on that 1 channel of the amp or even this very channel has some problem.
Thanks.
1 - 7 of 7 Posts
