1 - 8 of 8 Posts
hi every one...... my question is how do i got signal for my third amp? i already use all my pre amp output form my deck to my currents 4channel and one channel amp ..... so what do i do? please help :confused::confused::confused::confused::confused::confused:
Thats easy. So you have two amps, what are they powering and do they have RCA outputs? Am assuming your deck has front and rear only? Split the rear RCA's with Y-adapters (one female and two males) and walla.
Rca Y adapters, or if you current amps have line out rca's, use those. The outputs will be pass through of whatever is fed to the amp. So, be aware of any crossovers that may be applied upstream, they will also be applied to that output.
I got an extra Coustic XM3e new in original box.
yea i try not to use Y spilter, My current set up right now is Alpine 4 channels for high, DD M3a For sub and Tru Technology Line driver (quality enough PassTrol?) and also my deck have front rear and sub......
1 - 8 of 8 Posts
