Super stoked you got the manual. There should be another rubber capped hole up there you can poke a clothes hanger through.
If you have the glovebox brains, the quadlock i referenced should work. I think some of the newest vw have the brains but it's covered by a panel. You could disconnect the original brown piece with two small screwdrivers prying little tabs. Make you own 4 channel speaker wire leads and connect to the new brown piece to run to the amp. Then run your amp out to the original brown piece using some thin spades to plug into it. Speed wire (9 wire) would be simplist. The orm wiring is fine. I don't think the oem speakers will take more than 20w without crossing over at least 80hz.
