The stock tweeter covers in my Forester are in the sail panels.
The sail panel/tweeter covers are made from ABS plastic. I need to create some kind of a ring for the Seas H1396-04 tweets I want to use, but I am having trouble figuring out the best way to go about this.
I have attached some pictures of the sail panel covers, and the tweets, as well as the relative angle I want the tweets to sit, so if any of you master fabricators out there can shed some light on how I might accomplish this, I would really appreciate it.
This is the sail panel cover. The pointy end near my index finger is the top, and points toward the roof of the car.
This picture shows the bottom of the cover. This end sits along the top of the door panel.
This picture shows the general position of the tweeter as I would like it to sit when completed. I have not trimmed or cut the panel cover at all, and I would like the tweeter to sit inside the panel cover a lttle more than this picture indicates.
Here is a slightly different angle. You can clearly see the lip on the bezel of the tweeter. I would like this lip to be nearly flush with the sharp radius of the sail panel cover at the angle I have it positioned here.
Here is a picture of the backside of the sail panel cover.
Here is a picture of the Seas H1396-04 tweeter.
Obviously I will need to acquire some kind of ring, then attach that ring to the ABS plastic panel cover, then glass, or fill any gaps, then body filler, sand and paint for a nice black finish when done.
The part I am stumped on is finding a ring, and then attaching it securely to the plastic panel cover. The fill, shaping and finish I can do. Thank you guys for any help you might provide.
