Why are you selling?
If using IB, you don't need any extra power handling that the Apollo upgrade provides. Literally a waste of money IF running IB. If not running IB, I'm not sure why you'd consider the SBP subwoofer. But for IB, the SBP is one of the best available subwoofer drivers. GLWS.Do these have the Apollo upgrade?
You're very welcome. I tried to edit my post but I'm not a paying member so no dice. I was going to add, "For a normal car system NOT playing IB, there isn't a good reason to go with the SBP." The reasoning is the SBP doesn't have any advantages over other "car audio" subs except for IB, where it excels. And now the part I wanted to add, if you were going to use the SBPs for the home where you have more airspace to work with, the SBPs would be fine sealed or ported. But for a car my opinion is the SBPs should only be used IB; sealed or ported would just be too big and there are better drivers suited to a small car environment. Just wanted to make sure my answer was complete.That's a great answer . Makes perfectly good sense. Thanks for your reply.
