Full report attached as PDF.
Link to Driver:
Best I can do...
Acoustic Elegance • View topic - TD6M - the Lambda Series Little Brother
Measured T/S Parameters:
Re = 6.2509 ohms
Fs = 59.9615 Hz
Zmax = 72.2508 ohms
Qes = 0.2762
Qms = 2.9166
Qts = 0.2523
Le = 0.3836 mH (at 1 kHz)
Diam = 127.0000 mm ( 5.0000 in )
Sd =12667.6876 mm^2( 19.6350 in^2)
Vas = 7.7757 L ( 0.2746 ft^3)
BL = 13.2698 N/A
Mms = 20.6546 g
Cms = 341.0979 uM/N
Kms = 2931.7100 N/M
Rms = 2.6680 R mechanical
Efficiency = 0.5702 %
Sensitivity= 89.5783 dB @1W/1m
Sensitivity= 90.6497 dB @2.83Vrms/1m
Klippel Linear Xmax Values:
X Bl @ Bl min=82% 7.0 mm
X C @ C min=75% 6.3 mm
X L @ Z max=10 % >8.7 mm
X d @ d2=10% 23.9 mm
Sample Data:
Driver Picture:
Link to Driver:
Best I can do...
Re = 6.2509 ohms
Fs = 59.9615 Hz
Zmax = 72.2508 ohms
Qes = 0.2762
Qms = 2.9166
Qts = 0.2523
BL = 13.2698 N/A
Mms = 20.6546 g
Cms = 341.0979 uM/N
Kms = 2931.7100 N/M
Sample Data:
Driver Picture:
