Can anyone tell me what Acrylic is used in making windows in Subwoofer enclosures? How thick does it have to be? Any special types or characteristics that I need to be aware of?
That is an SWEEEEET box. Very nice job.There is a couple of types of acrylic (cast and extruded) with their own properties, but for this use either one will do the job exactly the same. You can also use polycarbonate (Lexan), but this scrathes waay more easily than acrylic. You can get scratches in lexan just by wiping it with a dry paper towel.
Thickness depends of size of the acrylic piece. Doesn't hurt to use the same thickness as you would use in wood for the same panel (well, maybe ut would hurt your wallet).
I have cut 20mm acrylic pretty easily with my plunge/track saw, but even easier is to get help from someone with a cnc. Most vendors can probably make you cut to order pieces as well.
This had 20mm thick acrylic as a window in the back wall, sandwiched between two layers of 22mm mdf:
