I recently found this site and have spend lots of time over the past 2 weeks reading; now its time for a massive 1st post
I am not at all satisfied with the current setup in my 02 Miata: Memphis 8" comps in the factory locations powered by an old 75x2 Alpine amp and a Nak 400 deck. There isn't any bass at speed, the midrange is muddy, and the tweeters are just plan awful. In addition, the Nak, while stealthy, has no processing capabilities and is picky with certain CDs. I have done quite a bit of research here and on the Miata forum, but still can't come to a decision. My original plan was to put some IB subs in the rear deck, but I have decided that I should address the components first and possibly eliminate the need for rear deck subs in the process. While I am at it, I figure I might as well give active a try.
Goals:
- improved sound quality & greater bass output
- no interference with operation of soft top(w/ glass window), boot, or hardtop
- not too pricey (ideally less than 1k in components)
- as stealthily as possible
Considerations
- Doors will be deadened/sealed
- Replace Nak deck with one containing active crossovers (Eclipse, Alpine)
- Deck or amp processing only; no space for a 2496, don't want to spend $$ on Alpine deck + PXA-H701
- This is a small convertible, so ultimate SQ is not really achievable
- I have some old amps laying around (50x4, 100x2) and can give up my spare tire, so it is not absolutely necessary for me to buy new ones.
Musical/Equipment tastes
- I listen to just about every thing from classical, through pop, rock, to techno. No rap/hip hop. Miata listening tends toward the pop/rock/techno spectrum
- I am used to metal tweets. My other car has MBQ QSDs and my main home system has Vandersteen 2Ces.
- I prefer SQ bass. I don't know how my bass quantity tastes compare to others, but my other vehicle is a wagon with a single sealed eD10o that provides more than enough low end.
With those requirements and my research, I have identified three major options as follows:
Option 1: 2 way with 8" midwoofer, 1" tweeter, optional rear deck 8" subs
woofers: Dayton RS, B&C 8NDL81, Adire Extremis 6.8
Pro: stealth, less complexity, easier to tune w/o opt subs
Con: hard to find tweeter that goes down to 1-1.5k for Dayton and fits in factory location, Extremis is $$, 88NDL81 is $$$, may still need subs which negates most pros
Option 2: 2 way with 8" woofer, 3-4" wide range, optional passive supertweeter
woofers: Peerless SLS, XLS
wide: Aura NS3, Aura NS2, Vifa MG10
Pro: easier to tune, could be stealthy, bass output without additional subs (no need to cut up rear deck), less amp channels required
Con: lack of high freq without super tweeter, glassing of door required for NS3 or Vifa
Option 3: 3 way with 8" woofer, 3-4" mid range, 1" tweeter
woofers Peerless SLS, XLS
mid: Vifa MG10
Pro: bass output without additional subs (no need to cut up rear deck), all in one solution - don't have to add subs or tweets later
Con: glassing of doors required ($$$, not stealth), more difficult to tune
I am mostly waffeling between 1 & 3. If the bass output of the midwoofer is sufficient, this will be the least complex, cheapest, easiest to tune, and most likely best sounding. If I decide that the bass output is not enough, however, I will end up with a 3-way system anyway. Installation of rear deck subs should be easier and more stealthy than glassed mids in the doors, but there is just something elegant about taking advantage of the available 8" holes in the doors for all low frequencies.
Goals:
Considerations
mid: Vifa MG10
