1 - 3 of 3 Posts
Hi mates
I want to connect GFI-4400 to GFA-4404, i have the 5 pins xlr connectors and a shielded 5 core cable, how to make the interconnecting cable? Any ideas? Will the 5 core cable work or do i need a 4 core cable? Do i connect the shielding to pin 1 for ground or do i connect a wire? Is there a need to interlink the negative pins to the ground?
Any sort of help would be appreciated
Thanks a lot.
http://www.rane.com/note110.html - Shows how to do it with a 3-pin connector, but the 5-pin is pretty much the same.
By their notes, a 4-conductor + shielded cable is fine... In your case, you can either connect the shield and a wire both to ground, or you can just ignore one of the wires.
Thanks for the quick reply sir
1 - 3 of 3 Posts
