I've seen the mad octopus you have in your trunk, you already know how I feel about that. Lol if your not having issues now, just see if you have issues after you put them other amps in. Then proceed.
I've seen the mad octopus you have in your trunk, you already know how I feel about that. Lol if your not having issues now, just see if you have issues after you put them other amps in. Then proceed.Im so confused i could **** the alphabet!
Im already $900 deep in 2x agm cells, and i dont want to screw with that mad octopus.
alternator provides electricity when the car is running. batteries provide electricity when the engine is not running. alternator also charges batteries whil car is running.My car/audio electrical is this:
180amp alt and 2x large gel cell AGM’s and when running my lights dont flicker and it will droop too 0v-.4v by all the meters from my cars computer and a bass control that reads it.
I just installed two amps that are twice the power my old ones had. And yes everything possible is fused. So know my electrical system needs a boost.
Buy what i read i have several solutions.
A new alternator, Which is a pita as ill have to pay to get it done.
Add a JP40 lithium cell thats all self contained with a remote and im rather sure an isolator.
DOWN4SOUND | D4S JP40 - 12V Lithium Car Audio Battery ( 6000 - 12000W )
Buy Car Audio Online the real #1 Source, Fast Free Shipping, EZ Financing, Price Match Guarantee, freebies in every order, Shop Now!www.down4soundshop.com
Buy a bigger lithium cell from Amazon as the are on sale.
with a dual lithium cell battery isolator.
lastly and its the easy way but mot the best imo is add another 12v agm Battery.
With all that info what do you suggest?
Your Honda is one of few vehicles that lines up nearly perfect for the titan8 5s batts. My truck cruises at 14.4 all day and can go as high as 15.5v when its cold or the computer thinks it needs to desulfate the agm cells. Which 15.5v would harm the titan8 5s setup. Even though I'm 99% of the time at 14.4.Yes used both RSV and the PWR, And it works perfectly for me. The DIY option would have been way cheaper but I don't have time for that. Plus I was scared of fvcking up. I also didn't want to play tetris in my trunk with cells.
It's been about a year now, and no issues what so ever. They are small and easy to install. But expensive. So I paid for convenience and ill do it again. I tested resting voltages before installing and everything checked out for me. My car charges in the 13s during the day and when the lights are on it stays at 14.4 so I'm not worried about degrading the battery. It works so 🤷🏽♂️
That goes out of the window with lithium and transient music. Lithium reacts so much faster and is so much more power dense. You can run way more power on much less lithium than agm. The alt doesn't even have to be very big since the fade in and fade out time between songs is usually enough to top lithium right back upalternator provides electricity when the car is running. batteries provide electricity when the engine is not running. alternator also charges batteries whil car is running.
Wow. 15.5, my max is 14.4 even on cold mornings. Yea that would harm the Titan. I have a volt meter up front to keep an eye on things and a Bluetooth Voltmeter at the lithiums. I use to test them out when I first put them in. I would blast full tilt on my way home from a night shift just to see how low I could drop them. But they barely flinched. Once in a while I'll log on to the app just to check if there is any abnormalities. It logs a trend of the voltage. But so far so good. They are expensive though but it was the best option for me and the Honda.Your Honda is one of few vehicles that lines up nearly perfect for the titan8 5s batts. My truck cruises at 14.4 all day and can go as high as 15.5v when its cold or the computer thinks it needs to desulfate the agm cells. Which 15.5v would harm the titan8 5s setup. Even though I'm 99% of the time at 14.4.
I run a bypassed control system now so I charge wherever I decide 14.8v constant right now with my agms.
Only reason I haven't went to lithium yself is the fact that my factory alt is quite big and I have dual batts factory. I can support 300amp draw easily.
That and I think I would need quite a bit of lithium to crank my diesel motor.
If they weren't so expensive I would try them for my truck but I'd be in for more money than it would likely be worth. A fresh alt will likely come first. Especially since I'm doing the serpentine belt and pullies really soon. Mechman makes a 400amp alt for my truck but I think I'll likely just stick with a 270 or 320. Anything bigger and you start playing with belt slippage.Wow. 15.5, my max is 14.4 even on cold mornings. Yea that would harm the Titan. I have a volt meter up front to keep an eye on things and a Bluetooth Voltmeter at the lithiums. I use to test them out when I first put them in. I would blast full tilt on my way home from a night shift just to see how low I could drop them. But they barely flinched. Once in a while I'll log on to the app just to check if there is any abnormalities. It logs a trend of the voltage. But so far so good. They are expensive though but it was the best option for me and the Honda.
v = i*rThat goes out of the window with lithium and transient music. Lithium reacts so much faster and is so much more power dense. You can run way more power on much less lithium than agm. The alt doesn't even have to be very big since the fade in and fade out time between songs is usually enough to top lithium right back up
Idk what lithium you have that rest at 12.6v but maybe throw them away and get something useful. Even 4s1p headways rest at 13.6vv = i*r
lithium batteries are generally at 12.6 volts while alternators usually put out over 13 volts. this is necessary so the alternator can charge the battery. when the car is running, the alternator voltage is greater than the battery voltage. the best upgrade for a running car regarding electrical output is upgrading the alternator.
Maxwell and ioxus are the 2 most common ultracap brands skelcap is another though they are hard to findThe lithium is just another battery no matter what its made from.
A capacitor bank would help,but then i have to wrangle the octopus over to it and then link back to my agm’s. And honestly im running out of room back there until spring when i do my final revision and finish.
Ebay has many good cap superbanks that arent that expensive and many more farads. So i can add that later if need be. DFS are way too expensive on these as 500f is $450
They are installed for now,But just not tuned with my scope. So i set it too 66% on the gain. Ive yet to see a clipping light also. I think Steve Meade showed an easy way to set your gains useing a clipping meter. But it will be done asap, I just put them in 2 days ago. The differances on the EvL’s was night and day. They hit with authority now and with a deeper tone. I turned my subsonic off and glad i did as i tried playing some rap “riding dirty” by Chamillionair and it didnt take long for the cone to bottom out. These amps are no jokes,as to why i got the thick box.I've seen the mad octopus you have in your trunk, you already know how I feel about that. Lol if your not having issues now, just see if you have issues after you put them other amps in. Then proceed.
this is a new one but you can get B stock for $134Maxwell and ioxus are the 2 most common ultracap brands skelcap is another though they are hard to find
finally some correct info. You might be in the lithium Facebook group.Idk what lithium you have that rest at 12.6v but maybe throw them away and get something useful. Even 4s1p headways rest at 13.6v
if I have my alt set at 15v and I'm using 6s lto banks, than the banks will supply power immediately no voltage drop at all. Because the battery is always in a point of ,ready to charge, and not in the full charged float voltage. You only get drop when you are charging in the float voltages. At 15.8v the lithium is fully charged and will hold that voltage until it's depleted. You don't need to keep a lithium 100% topped off like agm. It's better for the battery but less damaging than overcharging
If you have ever looked at a lithium drain test you will notice that they hold voltage for a long time before immediately dropping severely unlike agms which drop voltage linearly.
Again I get ohms law and ohms law stays true but battery drain curves throw that argument out the window when you aren't dropping voltage. When voltage is dropping .2v instead of 2v it's vastly different
You're going 6k?? craziness.I will eventually do a bunch of modifications to my car including the alternator soon as my warranty expires. Still got an other year. Then 6k salt it is for me. But in other to support my sounds now I went with 2 lithiums in the back an a AGM stater battery. I used the xs-power Titan8's, A RSV and a PWR S5's. But my woltage holds steady for the most part even full tilt in traffic.
Yea lots of good info on there
Eventually, when ever I decide to upgrade the alternator. I'm sure that will blow them SQLs. LolYou're going 6k?? craziness.
