1 - 3 of 3 Posts
Hello!
Hope everyone is well
I need an advice:
I have 2010 Cadillac CTS, with pretty much stock infotainment system.
Why pretty much? - due to excruciatingly high taxes on cars in my country, whatever they can install here they do. So this car has external BURY X Bluetooth module (which is horrible) - it uses external speaker,
and the GPS is also external module (some kind of pc based on Windows CE) because I doubt anyone in the world uses NavNGo navigation systems - the company is local. despite gps being external device - it works with original touch display Of the car! (Only the resolution is low).
so, I thought - maybe there is external device out there, that I can install instead of the gps unit?
what I want from this external device is
  • either CarPlay plain and simple = waze, calls, music, etc.
  • if not, at least support for Waze, and phone (BT for phone calls) (some kind of android based device probably)
  • in any case I want to retain touch control on the built in screen = I want “the device” to work with cars original touch screen.
please advice is there such a device?
alternatively if some one has technicians manual for the system, or a picture of the back of the oem unit with description of the cables - it may also help.
i will have another problem to solve - currently the BT and GPS use external speaker. I will have to figure out how to connect “the device” to car audio system (cannibalize the AUX input perhaps?).
anyway, I will appreciate any advice.
Thanks!
Here you go, been looking to possibly upgrade our CTS at some point and these appear to be the most popular options available:
I'll probably go with the navtool unit if I do, but I've also debated the Metra kit and an aftermarket head unit:
My biggest hang up with the Metra is that it leaves a bunch of unused buttons on the console that are related to the OEM head unit. If it were my car, I would likely be OK with it, but it is my wife's vehicle and I don't know that she would be happy with an entire section of the console being useless.
Thank you very much!
I will probably go with Metra, since the car is all mine.
option 1 is also interesting, but I heard from technicians here that quality is not very good
anyway, thanks and good luck with your car!
1 - 3 of 3 Posts
