My truck didn't come with auto anything I added it all. Now I'm wanting to add a dei 530t but need some help wiring it up. Here is how my windows are wired up but I can't figure out how to add the 530t to it using the instructions, hopefully someone can help me out.
Based on your drawing; you installed two relays that control the power window....is that correct? Using a two position switch; you feed ground to one relay coil and the window goes up, feed ground to the other relay coil and the window goes down....?
or
Did you install power switches into the door/doors that eliminate the need for external relays (frequently provided when you purchase a power window kit)? All power and ground circuits for the motors run through the switch.
Yes, each window I put a relay and ran them to the factory switches and factory motors I got from another truck.
