1 - 2 of 2 Posts
DIYMA Founder
Frequency response measured unbaffled. Spl looks to be about 92dbwm. I can't explain that weird suckout at 8khz, except to say that it occurs in almost all the measurements. Pretty good off-axis response though at 60 degrees. You'd definitely want this to be mounted extremely off-axis for the smoothest response, although you do lose quite a bit of sensitivity.
Looks squeaky clean.
Overall excellent decay times, except at 8khz where it looks pretty bad.
3khz.
5khz.
8khz.
12khz.
15khz.
Distortion measurements all taken at 96db @1m. Pretty loud.
Definitely don't want to cross at 2khz, due to the high distortion.
3khz is a great place to cross over. Very low distortion above this point, although 3rd order products could be a bit lower.
Qts is a bit high, which explains the bump around 1.2khz.
Pros:
1. Good extreme off-axis performance
2. Generally good distortion and fast decay above 3khz
Negatives:
1. Very rough on-axis response and strange severe suckout at 8khz
2. Not suitable for use below 3khz
i really didn't like these tweeters.....
but, i had them mounted pretty much on axis. i'd try them again, but a terminal snapped off one of them. oh yeah, and i got some dayton rs tweets, and you'd have to pry them out of my cold dead hands to get me to give em up :D
1 - 2 of 2 Posts
