· Registered
Hi All,
This is for one of my friends, he deals with B2 audio and wanted me to model an enclosure for B2 Ref12. The company recommends only sealed box between .7 - 1.2 Cuft which was surprising to begin with since the EBP for this is around 92.7 which is ideally suited for ported (IMO). To add to this, the Q for the box as per recommendation is < .5 which comes under critically damped enclosures. WinISD gave a not-so-surprisingly high value for F3 (>70). Attached are the screenshots of Winisd. Any pointers/suggestions would be really helpful.
T/s for the driver for your ready reference:
Power handling*: 600 wrms
Sensitivity: 88,3 dB
Nominal impedance: Dual 4Ω
X-Max: 20 mm
Equivalent Compliance (Vas): 114,3 L
Free Air Resonance (Fs): 20,4 Hz
Electrical “Q” (Qes): 0,22
Mechanical “Q” (Qms): 3,52
Total Speaker “Q” (Qts): 0,2
DC Resistance (Re): 4.2 Ω
Magnet weight (Oz): 2 x 76 Oz
Thanks,
Venki
· Premium Member
I don't trust those specs. I've been measuring drivers for a couple decades now, and I've never seen a woofer than genuinely had a qts of 0.20.
I'd order a Dayton WT3 or DATS and test the woofer before building a box.
· Registered
Thanks Patrick for pitching in :). I do have WT3 in hand, will measure the specs once I get hold of these and post it here. Hope specs would turn out to be different from what the company says :).
Cheers,
Venki
