Can I install an aftermarket stereo in a hybrid Camry? Nothing crazy but would want amps, components, subwoofers; maybe 600ish watts rms? Would like to keep stock HU with PAC kit and level signal with 4x8 DSP.
So you have the pioneer amp then? And it was that bad?You could but replacing the headunit will make a significant improvement in SQ.. More so than adding that dayton DSP. Unfortunately the factory headunits in this generation Camry have very poor signal quality... that a DSP just can not correct for (noise floor, poor dynamic range, poor stereo seperation).
I have a 2015 XLE that came with the Non JBL Nav and the biggest difference was realized when it was replace. All the factory functions for the car remained intact by using an Idatalink Maestro RR.
The entune premium with Nav (non-jbl) did not come with an external factory amp and the factory headunit was manufactured by Fujitsu... which I believe is in all the 2015-2017 Camrys.So you have the pioneer amp then? And it was that bad?
They shut down entune for Lexus. Yeah that sucks everything was powered by the Fujitsu - the pioneer in Lexus cars and the older Camrys sends a clean high level. All the crossover stuff is done at the drivers.The entune premium with Nav (non-jbl) did not come with an external factory amp and the factory headunit was manufactured by Fujitsu... which I believe is in all the 2015-2017 Camrys.
do you really need big three at 600 watts? It never hurts to do it, but is it needed?You should be fine at 600- 1000 rms on the stck alt and battery. I would do the big 3 first .
