The only advice I can offer is NEVER put motion sensors near your vents because the hot air rising from them after you turn off the car will constantly set them off.
Lots of pain generators = GOOD!
Looks like you went with a really good setup. I have a very similar setup with the Viper Responder LE, 2 window modules, trunk solenoid, 2 mini piezos, proximity sensor, digital tilt sensor, and a couple other tricks.
I personally love the system. It is by far the best DEI product I have seen in years.
Couple of quick tips for your install though.
1. Doing piezos and the glassbreak. If the piezo is too close to the audio microphone for the glass break sensor, it will always trigger full alarm and you will loose the warn away feature. When the alarm triggers warn away it will chirp 4 times and depending on placement the piezos chirping will trigger the glass break and send the alarm into full alarm mode. So chirp chirp chirp then wam! full alarm. Either mess with the placement of the piezos and the mic, or wire the piezos with a relay off of the horn honk output and have them only trigger during full alarm mode.
2. The trunk solenoid is a major PITA. Especially with all the sound deadening you have done.If you are doing it the stealth way and running it off the latch near the bumper (instead of mounting it to the trunk lid) it takes a lot of tweaking to get it to work. You will need to hammer the metal of the trunk liner to allow for the solenoid to tuck under the lip. You may also have to weaken the spring on the trunk latch mechanism.![]()
Have fun, you have a ton of work ahead of you! I think my entire install probably took between 10-12 hours. And I install these everyday at work.
Thanks for the input, but I don't see how this helps ANYONE, including me??i did a viper 5901 2 way 6spd alarm, keyless, and remote start with
backup battery,
2 sirens under hood,
1 piez0 inside
ultrasonic radar for inside cabin, dual mic adjust sensitivity
starter kill
triggers on door, hood, and trunk,
tilt sensor built into factory alarm.
Rob, thanks....Aaron, great list of stuff...
I agree on the piezo's... the more the better. Also, use the Alarming out for the piezo's to avoid the warn-away falsing.
The 1 thing I love about my Clifford Matrix Responder is that it too has the built in turbo timer function that is adjustable from the remote.
the Ultrasonic sensor designed to sense changes in cabin/interior pressure. Its a good sensor, but its not very adjustable, as I remember. I am a huge fan of the 2-stage proximity/radar sensors. The warn away is on the impact. The 2-stage radar allows you to set interior & exterior perimeters/parameters to your taste, where you are parked, weather etc.. they used to have an attractive console/dash mounted control pad. Not sure if they still do. I would NOT use the DEI version of the Radar sensor, as it is RF based & lacks the DSP used in the Clifford Proximity unit.
Be sure to mount the back up battery where YOU (not a theif) can get to it fairly easily for servicing... I made that mistake on my F150. They are lead-acid style batteries, so they do really need mounted to vent outside.. I bought plastic electronics project box that was just big enough. then ran a 3/8" vacuum hose through the floor.
As its commonly said, install is everything. Having an experienced Directed installer is HUGE. You got lucky on that one.
last thing, LED's LOTS OF THEM... I have my main one installed on the bottom of my rear view mirror. aiming toward the dash top. When its dark out, it lights up the entire front compartment. When I take the car apart (again) for the deadening, I plan to put the Electro-Luminescent flat badges on the 2 front windows or at least 1-LED per door top. Just put them on a relay off the main LED output.
My F150 had one on each of the 4 door panel tops, one in each white back up lens on the bed sides, one in each lower corner on the headlights/markers, the under mirror in the interior.. lol... it lit up a 2-car parking area around the truck...
good luck.. take lots of pics... I plan to add detail shots of mine with my build log...
Rob
Aren't they the same? DEI?I would NOT use the DEI version of the Radar sensor, as it is RF based & lacks the DSP used in the Clifford Proximity unit.
Thank you Sir, I too was wondering when you would see this...Aaron, I did an 08 WRX 2 weeks ago, and my installer got frustrated with using a solenoid on the trunk pop. I ended taking over and used a high powered DEI 524N instead on the bottom latch and it worked like a charm. If set up right, the actuator will go back to its original state without having to pulse it back the other way.
Also txwrxwagon is right, even though there's several brands under the DEI umbrella, some of the components are built different. Viper, Python, Avital may carry the same components but Clifford often have a line of their own.
Be sure your brother sets up your trunk and hood pin with your alarm on top of the door pins. Back up battery and siren is priority over the other sensors. Other than that, you should be fine with the extras.
Yeah, i've always ran with Clifford myself.. I'm trying to think what my old RS had in it... had the 4 button remotes with the "shift" button on the side.. Had the same thing in my VW prior to that as well...One thing DEI didn't f*ck up in its acquisition binge, was Clifford. Clifford has shared most of its technologies with the DEI brands, however they have kept the absolute best technology for the "premium" level. Clifford benfited from improved remote range (the #1 achillies heel of the original Clifford lines) & better marketing & support.
I have only owned Clifford alarms. They have never let me down.
I will take Ves's advice as well, I have been wanting to do hatch release on my WRX wagon & just haven't done it.. I will look @ the 524n myself.
Thanks for the insight.. !The Clifford RSX 3.3X, Viper 5701, and python 872 are all the same except different transmitters. So the OP's system does not really change depending on which Directed brand he uses.
I installed the RSX 3.3X on my G35 and love it. And yes, the shock sensor is built right into the brain on the responder LE's. I don't have any experience with the add-on modules though. Also nice that they include most of the relays right in the brain, not a ton of extra wiring needed.
Ok... I am going to tone this back before I post it... lest I live up to my arrogant-ass reputation....The Clifford RSX 3.3X, Viper 5701, and python 872 are all the same except different transmitters. So the OP's system does not really change depending on which Directed brand he uses.
there ya go.. hopefully the red worked right.Hi all,
It's time.... time to finally start my install... First I need to buy some sensors...
I have a Python Responder LE base unit and I'm looking to add these add-on sensors..
530t- Window moduleKEEP
520t- Backup batteryKEEP
515r- Backup battery sirenKEEP
513t- Mini Piezo siren x2 (or 3 or 4) KEEP as many as you can![]()
509u- Ultrasonic sensorTOSS
506t- Glass break sensorKEEP
ADD Clifford's Dual-stage Proximity Sensor
What I would like to know is, an expert opinion on what I have on the list... What might work better, or differently for my app..
I have a VERY confident installer lined up for this (my brother, ran a Directed based install shop for 5-6yrs) so the install isn't an issue, but, he's been doing other things for a few years so, the up-to-the-minute for him is gone..
Thanks in advance for any and all input...
Aaron..
PS.. of someone could "direct" me to a place to get these cheaper, please do so... right now I had a combination of Amazon and Audio Discounters working for me, but I'm finding other various sites with better prices.. am I better off, picking things from all over the net, or buying in one spot??
