Ok, first I want to start off by saying I used to think I knew at least a little about mobile audio, then I joined this forum.
:blush: I now know I have very, very much to learn. But anyway! I'm going to begin a completely new audio build in my 2010 Civic coupe Si. Initially I was thinking I was going to piece together various parts consisting of:
1. Pioneer double din HU (always like Pioneer HU's)
2. 2 6.5" component sets (car has 2 6.5" in the doors and 2 6.5" on rear deck)
3. 4 channel amp for components
4. 2 12" subs
5. mono amp for subs
I decided to go with the Pioneer AVH-X4700BS for my HU, I can buy it for around $320 new and it has some good tuning features for a DD unit.
I then stumbled upon the Pioneer GM-D9601 and GM-D8604 and thought those were some pretty impressive specs for the money; the mono does 1200w rms @1 ohm and the 4 channel does 100w rms x4 at 4 ohms, both can be purchased for around $300.
I also see the Pioneer TS-W3003D4 12" subs that are rated for 600w rms and can be bought for $160 for TWO.
I thought to myself, if I'm going to go this far, might as well complete the build with some Pioneer components, and found the TS-D1720C, which are reviewed really well for their price of around $100 a set.
To finish off the build I'm going to install sound deadener in the doors and trunk at least and add a second battery. I'm planning on running 2 awg welding cable for power and doing the big 3. I want to use decent quality RCA's and run all new speaker wire to the components. I have a budget of around $1500. I absolutely do not want to skimp on things like wiring and sound deadener though. I'd rather only tear my car apart once for this project, if I'm going to save money in any area I'd rather it be in speakers and amps, as those can be replaced easily. I'm also not an audiophile and this will actually be my first time with component sets, I've had quite a few different coaxials but never components, so I'm sure this will be a significant upgrade over any system I've had in the past. I also listen mainly to different types of bass heavy electronic music and some rap, other stuff too but that's what I like to BANG! I basically like to be screamed at and beat up by music.
So far:
1. HU - $320
2. Components (2) - $210
3. 4 channel amp - $138
4. Subs (2) - $160
5. Mono amp - $170
6. Sub box - $170
7. Wiring - ~$100
8. Sound deadening - ~$150
9. Harness/mounting kit - ~$70
10. Misc - ~$50
Total = $1,538
Couple of questions:
1. I find that most builds on this forum use only one set of components in the front and usually coaxials in the rear, is there a disadvantage to using 2 sets of components? I just feel like when running a 4 channel amp it makes sense to have 2 matching sets.
2. I'm wanting to go with a box built buy ZENclosures that is specific to my model of car which is sealed and has ~1ft^3 and the recommended volume for these subs is 1.25ft^3, is that an issue I should be concerned about?
3. The components are rated at 60w rms @4 ohms and the 4 channel I'm considering does 100w rms @4 ohms. I'm guessing this should be ok as long as my gain is set modestly but due to my limited knowledge I generally try to match these pairings closely. Issue here?
Thoughts on parts? Suggestion on a way to save money perhaps? Let's flame the newbie?
Any comments welcome, thanks for looking!
4. 2 12" subs
So far:
1. HU - $320
4. Subs (2) - $160
5. Mono amp - $170
6. Sub box - $170
7. Wiring - ~$100
10. Misc - ~$50
Total = $1,538
