So as topic says
I want to chat about measurement gear, mics, REW, measurement methods, impulse responses and impulse centering, fir,iir,APF….. 😙
so last few months I’ve just lost confidence in the usb mics from Dayton and minidsp.
they produce good sounding results but it’s not great sounding. It’s just not.
back in the 90s and early 00s I used my audio control 3050A RTA with stereo un-correlated pink noise on CD from the 95 or 99 IASCA CD. Period. I would reject any other noise source because I could not trust it…..
I don’t know what audio control did back then with there noise and IASCA. But they had something very very special. And it’s sad to see that level of accuracy be replaced by these chintzy little gadgets while we wave them around like a magic wand and they’re completely in accurate.
back in the 90s when I first tuned my Jetta with a pair of Alesis MEQ-230s. One on subs and one on highs. I could make a tune that had a harmonic balance that was simply amazing. Vocals and synth had a tone (spectral balance) that was in Harmony and it gave you a sense of realism that would draw emotion from the artist… listening to Mary Chapin carpenter stones in the road on CD on 16/44 and it kicked the crap out of everything today…
here we are 20 years later with a laptop and these devices, Dirac, room correction, fir whizz filtering….. and all you need is a simple 1/3rd octave eq and a good analyzer and a proper install and you didn’t need all this stuff. But we have it. And it’s fun….. but we are not making accurate measurements as a community and promotion of almost gimmickish items.
Mics: usb vs xlr….. I’ve said before , I have the umik1, UMM6, a CM-10, a ECM-8000 and a Dayton IMM10 (phone mic) and now an array of 8 total cm-10s. The cm-10 paired with the audio control 3050A is the only setup I trust…. Hum weird. It’s 30 years old and better then everything else I have.
are the usb mics close. Yes, usually very close. But it’s not precise and I would suggest there’s some anomalies that change the responce…..Hot cold tge compute it’s on, etc etc…. Assuming everyone’s software is configured properly as well.
im a dirac live user. I also make my own corrections in rephase fir. I need a accurate mic and rig. And I believe xlr is choice and you get what you pay for…… I’m happy with the performance of the cm-10 it’s a 150$ mic. I want a earthworks mic , sure….or some 3000$ super high end mic. But I think we can make it work with less expensive stuff….
i think everyone needs to have a reference setup that never changes. Something that is known good and made for eachother. Weather it be a 30yr old rta or one of those handheld analyzer’s with built in mic. Something calibrated and not a plethora of laptops and cables and brands mix matched…. And if it be that, put it up against something that is known good and make an offset.
I’ve personally experienced deviations with usb mics. One day it’s working and next it’s not… same laptop, same REW install. Nothing changed except the weather.
all I know is when I work a set of Eqs with live rta, I shoot for my target to be within 2db max. Any stray peaks needs to be tamed. I don’t just knock the peaks down and leave a jagged response. Although sometimes I tune a car and it comes back months later for a upgrade and retune and it’s changed…. Speakers once broke in should retain the same thing for at least a year.
Why does the umm6 have better sounding HF then the umik1… like the 0deg file, on the rta there super close, but different sounding. There both the same standard, why do they produce a different sound. So so strange. Both 48k mics with Java drivers. Strange
why does the cm-10 have such a different shape and produce a tune that sounds 10X better then minidsp and Dayton… the only problem is getting XLR into your PC faithfully. Like my CM-10 on REW matches the audio control meter to 10khz. Then there’s a cut! I assume it’s the tascam interface, looks like all the analog inputs go directly to an ADC when I open it up. So it’s not the soundcard rolloff from the analog outputs…. What gives…. That’s just one thing I caught. Amongst the many small deviations I run into non stop.
i can’t wait to get my Roland sound card, and fire up some smaart. I hope so much it’s accurate and consistent.
pointing mic up seems the preferred method for reflective environment. The 90deg cal is choice.
And measurements with Dirac. Tonal issues completely solved using xlr mic. Very very different looking responses between xlr and usb. And the xlr mic makes Dirac kick butt!!!
What I’ve been doing lately is using my 3050a and cm-10 and in Dirac make a target and make anchor points at every 1/3 octave ISO. And run Dirac and measure with pink noise from iasca cd and use my Dirac points as a 1/3 octave EQ.
here’s a pic with a Dirac tune using same mic as the 3050A… RTA is set to slow with 2db per step. Dirac is deadly accurate with same mic except 10-20k I had to bring up….. see these comparison pics….they match surprisingly well otherwise, BUT STILL ERRORS that I wouldn’t have known otherwise
bringing that up make the whole harmonic balance fixed and the sound is absolutely breath taking real sounding….
anything anyone can add as far as tips or things they do for a accurate tuning rig please share
