1 - 1 of 1 Posts
Listed as almost new because it was powered on before but decided to go a different route. You can tell by the feet that it has never been mounted to anything. I would rate the condition of this amp excellent, 9.5 out of 10 (10 being new). They are $279 new. You can save some money if your in the market for this amp. $240 Shipped in lower 48. Sorry that the first picture is upside down, I flipped it but it keeps going upside down. My ebay account is EEclipse16.
Channel(s): 1
Output Power (RMS)
12.5 VDC Power Supply
Power output @ 4 Ohm: 1 x 500 Watts
Power output @ 2 Ohm: 1 x 800 Watts
Power output @ 1 Ohm: 1 x 1200 Watts
T.H.D. 4 Ohm: <.1%
Frequency Response: 20Hz -- 1kHz
S/N Ratio: >90 dB
Input Sensitivity:
Lo 0.8-8V
Hi 0.2-2V
Bass EQ @ 45Hz: 0~18dB
Phase: 0-180 degree
Sub Sonic 15 --- 35 Hz
Crossover (Butterworth): LP 50 --- 200 Hz
Input Impedance: >20KOhm
Idle Current: <2A
Damping Factor: >200
Dimension: W(heat sink/foot) X H X D: 458x63x268mm
Sent from tapatalk.
1 - 1 of 1 Posts
