1 - 1 of 1 Posts
I received a pack of Alphadamp a couple of days ago. I installed 5 sheets in my rear door of a Land Rover Disco. I covered as much of my inner panel as I could and almost the entire outer panel that would be covered by the door trim.
It was easy to work with. I just used a razor blade to cut thr sheets to the size I wanted. The metal outer layer is thicker and the adhesion was great.
I have 2 6.5 subs in the stock locations and have 400 w powering them at 8 ohm. Alphadamp worked great and I do not have any unwanted noise from my rear door. I will definitely use again!
Mobile Photobucket
Mobile Photobucket
1 - 1 of 1 Posts
