1 - 12 of 12 Posts
Ok so I cant figure out crap on this deck lol no manual to be found online either.
I figured this be the one place to get help.
1 how do you turn the AUX on? I bought a cable for my ipod but cant figure how to turn it on lol
2 how do you turn sub off and on?
I had this deck back in the day and to get my Ipod to work, I had to get an Alpine adapter (KCA-801b) which interrupts the Ai-net signal and allows you to pipe in your Ipod (or other MP3 device of choice). Also had to install a two-way rocker switch to activate it.
Check pacparts for this adapter, if it's still available.
Good luck
The bass/subwoofer output has a trick to it. Check youtube, some guy posted a vid showing how to turn it on and off, I have the manual but no time to check it right now.
I'll email it to you, pm me your email.
Oh I had one and it was pretty sweet, but hated the fact that it took so long to read CD-R's. And no CD changer meant CD in CD out all the time.
Good luck
Here is what i bought for it
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
pm sent and ill check youtube thanks
FOR SUBWOOFER OUTPUT
STEP 1.Press and hold the PWR button for at least 3 seconds.
STEP 2.Press the F2 button repeatedly to select "SUB.W." Each press of the F2 button changes the modes as shown at left.
Note:If you press the F1 button the display scrolls in reverse sequence.
STEP 3.Press the <<DN or UP>> button to turn on or off the output to the subwoofer amplifier.
Each press toggles between the ON and OFF modes.
Notes:
· Initial mode is "SUB.W. OFF".
· Set to the "SUB.W. OFF" mode unless the subwoofer is used.
· When the subwoofer is turned on, the subwoofer output level can be adjusted.
STEP4.Press the PWR button to set the selected mode.
FOR AI-NET
Follow all steps as for subwoofer ouput, but in STEP 2 instead of "SUB.W." select "D.OUT.".
OH and don't forget to click the "THANK YOU" button on the bottom right hand coner of this post.
lol clicked
this would explain why the f2 button is wore off lol.
but hey i cant complain i got this thing pretty dang cheap and only the f2 is wore off :)
I had two and sold them, I like the SQ and BlackOut Mode but hated the way it took forever to load CD-R's and I never really about using the AI-NET with an Ipod player.
actually when i got it i threw in a cd-r to see if it worked took like 5 sec and it started pllayin. but heck i doubt ill ever use cds there so yesterday im to mainstream for that lol
ok found the d. out setting but how do i get it so it goes there now lol
i can get it to tuner and cd. i cant get it to shuttle ai-net
Not sure since I never used it but am assuming it has to detect some type of source from it before showing up on the source menu.
So I would turn the device on and plug it while playing music and press "SOURCE" button.
Discussion Starter #12
Ok so I think I got it.
There is a pink wire in the harness. INTERFACE this needs to be grounded via a toggle switch, so you can turn it off to listen to radio or cds,
Also I shut the mute off for AUX and the INTERFACE.
Thanks for all the help
1 - 12 of 12 Posts
