1 - 5 of 5 Posts
Ok so i got me a used iva-w205 on ebay.
Got it hooked up in my 1989 Vw Jetta - I will make a thread next , i swear..
Anyways, i downloaded manual for it and it still doesnt make sense to me.
It works great.
The display hides like immediately after hitting a button, kinda annoying. I hit set up and it only give me the audio set up menu.. cant figure out how to get to the video / display menu. ( i even read manual and it says to hit >> button but i dont see the >> button....
So i have a tr-7 by-pass that came with the unit. Already pre-wired so i just powered it up as is.. im wondering after viewing their website if i need to program it for it to allow me to see display fully?
I threw in a dvd and it plays the audio and says dvd-v on the top but it does NOT show the actual video?
I am very confused? Any help?
Here is link to my install on a vw forum, i will repost it here.. trying to get it rollin' before dark..
VWvortex Forums: Double Din radio install in stock center console
Here is pic of unit installed in my Jetta.
Moderator
if the video isn't coming up, there's your problem. they bypass isn't wired correctly; otherwise you would get video.
once you get video you'll be able to see the menus you want.
in addition to the above, the bypass unit is defaulted from factory to work with your alpine deck, so no need to re-program it, just re-wire it properly (the website has the diagram).
btw, nice recaros on that MKII.
well i bought the unit with the tr7 on ebay and it was already pre-wired..
I checked it against the website and its wired up right.. it was in the "off" postion.. so i moved it to on but still no video..
What i find odd is that i cant even get into the set up menu to set the clock? Is there some sort of user lock or something?
The screen only stays up for a few second after i make a selection..
I have re-read the owners manual several times and the buttons are not visible that i need to even set the clock??
Since the pac-audio thing was in off mode, do i need to maybe cut off the power to it and try it again? but it doenst have a constant power only ignition power so in theory it shouldnt retain memory?
Im confused...
6 hour installation now 2 hours trying to figure out how to make it play.
Other than that i love the unit.. so far only played with it in stationary position on my car.. i have xm and ipod hooked up to it. I was going to go with a 505 but found new 205 on ebay for $400 so i did it instead. (its on way from MI, the one currently in car i got for $380 on ebay last week)
I will also be installing another 205 into my 05 passat next week. I hope to have this figured out by then...
1 - 5 of 5 Posts
