1 - 3 of 3 Posts
Discussion Starter #2
Maybe a more specific question:
Should I use 2 amps to power a coil each of the 2ohm dvc sib?
Or use the parallel option and wire the dvc sub in series so it presents 4 Ohm?
Well, its in the car, just need to find time for proper setup.
Ran into one hitch already....
Either the amp or the wifi module drained the battery...
Have to admit I never checked the amp was off after checking pc connectivity and app connectivity, so more research is required.
Are the 'switched' signal wire and the autosense mutually exclusive?
1 - 3 of 3 Posts
