Hey guys, I have a pair of PDX-V9. My plan initially is to use one of them to power my horns and midrange, and to use the other one bridged to the midbass and the 5th channel to the sub. In the future, I may consider using both 5th channels for the sub- one to each coil. All processing will be done with my PXA-H800 so all amplifier filters will be set to "OFF."
I am trying to figure out how to configure the amp/inputs etc. The manual is a bit confusing. It only provides two options that are relevant to what I'm trying to do.
Option 1 would require that I use the same amp to power the SW as I am using for the horns and midrange:
Option 2 would allow me to bridge the first 4 channels to the midbass, and use the SW on channel 5, but not use the SW RCA input, and instead, sums the input from the midbass channels for the SW:
Is there a way to configure the amp in a way that allows me to use the SW input and bridge ch 1-4 to the midbass? It would seem as simple as changing the SUB W input selector to "SUB W" but I am not sure why Alpine did not include that as an option or why they defaulted it to sum ch 1-4.
I'd also assume I can use channels 1-4 without using the SW channel.
Any help would be appreciated! Thanks guys.
