1 - 12 of 12 Posts
Pioneer DEH-80PRS active Alpine 4.150 Satori TW29D Audio Development W600 Alpine 1.1000 JBL 12GTI
I have a few items for sale :)
1) Planet Audio PA-6005 5ch amp
50 x 4 & 200 x 1 at 4ohm
100 x 4 & 300 x 1 at 2ohm
Made in USA, clean power & crossovers. Shows typical signs of use for an amp of it's age.
I decided to give the 56k guys a break and will provide a link to pics at the end.
2) Alpine MRP-M650 class D mono amp
Class D mono subwoofer car amplifier
400 watts RMS x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
Variable low-pass filter (50-200 Hz, 24 dB/octave)
Tuned Bass EQ (0-12 dB bass boost at 50 Hz)
Subsonic filter (24 dB at 15 Hz)
MOSFET power supply
CEA-2006 compliant
STAR Topology (minimizes internal noise and prevents ground interference)
Speaker- and preamp-level inputs
Gold-plated screw terminals
Fuse rating: 30A x 2
12-13/16"W x 2-3/8"H x 9-9/16"D
I bought new at a local shop (Dedona) and used about 4 months. Been sitting in my condo since.
3) Image Dynamics Chameleon CXS62 components (2ohm version)
6.5" COMPONENT SPEAKERS
150 WATTS RMS
SENSITIVITY: 91dB
FREQUENCY RESPONSE: 45-4KHZ
NX30 TWEETER
EXTERNAL CROSSOVER
Mounting depth: 3.125"
Mounting Diameter: 5.625"
Magnet Diameter: 4.5"
Bought new and used about 9 months. When Dedona swapped them out one of the wires got pulled off of one of the tweeters. I soldered a wire on and tested it works fine. One of the crossovers looks as though something hot got on it and the plastic cover is disfigured. Not sure what happened but they worked fine when pulled. I just spend lots of time changing speakers. (if I had discovered this site earlier I wouldn't have pulled them, just gone active)
4) Onkyo TXSR-502 6.1 surround receiver
Bought new when I worked at Circuit City about 5 years ago. Works perfectly. For the past 4 years I have been on the road Monday thru Friday so it has only seen weekend duty. Only reason I changed was to step up to HDMI connections. (TXSR-602)
Pics can be seen here:
stuff for sale pictures by jman33163 - Photobucket
Prices:
1) $150 shipped
2) $150 shipped
3) $150 shipped
4) $200 shipped
All prices are or best offer but please be reasonable :) Might be interested in trades depends on what ya got?? I need off the top of my head, some deadener for my doors and I really could use an inexpensive cd player for my work truck and maybe some speakers with it too. (Freightliner box truck so nothing too fancy :D )
Hit me up in this thread or shoot me some PM's makes no difference to me
Jman
Bump for the day! :)
Also have one more thing to add to the list.
5) Diamond Audio D6 12" D4ohm
A really great sub, only single sub I ever ran that was louder was a RE15. There are a few dings in the cone but none go all the way through and have not affected performance one bit. I also have a ported box built to specs for this sub that really mates up to it very well! Pics of the sub have been added to the photobucket link above. I haven't taken pics of the box yet but can have some by Friday night. (I drive a truck Mon-Fri and won't be back to GSO until Friday afternoon)
12" Dual 4 Ohms D6 Series Subwoofer
Power Handling:
Peak: 1200 watts
RMS: 600 watts
Impedance: Dual 4 ohms
Hard anodized alloy cone woofer
NBR "Omega" Surrounds
Cast aluminum alloy frames
Dual mirror-image flat spiders
Inter cooled motor design
Vented pole piece
Aluminum dust cap
Integrated heavy duty lead wires
3" Extended voice coils
Price as follows
Sub alone: $125 shipped
Sub with box: $175 shipped
Box alone: $75 shipped (is very heavy, 3/4MDF slot-ported)
Again, all prices are OBO
Thanks guys
Jman
What's happening everybody! Are we all ready for a great weekend? I am! It is going to be in the upper 70's Sat and Sun. This after 6 inches of snow on Monday!! Everyone be safe and stay out of trouble.
Oh, BTW
Bump :D
Jman
Bump it up
I got some interest in the ID comps so far. Everything still available.
I also forgot to mention, I only accept Paypal unless you are picking up in person, then cash is king
Here are the pics of the ID's. If anyone wants me to add other pics just let me know.
Jman
ID's have been sold to starboy869
Thanks guys :)
Rest is still available. Will be adding some Alpine Type S s components soon.
Discussion Starter · #7 ·
Up from land of the lost :)
Hi,
Whatever happend to I'd speakers? Did I bail or you bail? Either way I'll take them if you still have them.
Discussion Starter · #9 ·
Best I can remember you were gonna get back with me about them and didn't :confused: My memory kinda sucks but that is the best I can come up with :D
Hit me up with a PM and we will figure it out :)
Jman
Great guy here... someone buy his gear! :cool:
Discussion Starter · #11 ·
Thank you Mike :)
I wanted to add a couple more things.
PPI PC6600.2
6 x 50W @ 4 ohms
6 x 100W @ 2 ohms
3 x 200W @ 4 ohms bridged
THD: 0.02% (4 ohms)
Freq. Response: 4.5Hz ∼ 100kHz (±0.5dB)
S/N Ratio: 110dB
Damping Factor: >500
Max. Current Draw: 100A
Fuse: External 80A
Dimensions: 19.75" x 8.98" x 2.24" (50.2cm × 22.8cm × 5.7cm)
Manufactured in 2000
http://i639.photobucket.com/albums/uu112/jman33163/stuff for sale/littleofthislittleofthat087.jpg
http://i639.photobucket.com/albums/uu112/jman33163/stuff for sale/littleofthislittleofthat089.jpg
http://i639.photobucket.com/albums/uu112/jman33163/stuff for sale/littleofthislittleofthat088.jpg
$150 shipped
Nakamichi PA506
6 x 50W @ 4 ohms
6 x 100W @ 2 ohms
1 x 250W @ 2 ohms bridged (ch 5/6 only)
THD: <0.01%
S/N Ratio: 100dB
Power Bandwidth: 10Hz ∼ 30kHz (-1dB)
Dimensions: 18.9" x 9.6" x 2.6" (48.1cm x 24.4cm x 6.7cm)
Built by Zed Audio
http://i639.photobucket.com/albums/uu112/jman33163/stuff for sale/littleofthislittleofthat090.jpg
http://i639.photobucket.com/albums/uu112/jman33163/stuff for sale/littleofthislittleofthat092.jpg
http://i639.photobucket.com/albums/uu112/jman33163/stuff for sale/littleofthislittleofthat091.jpg
$300 shipped
Used but in new condition Eclipse 8 disc cd changer CH-3083, 10/10 cosmetics and functionality, bout the only way to tell it has been installed is the sticky tape on bottom of changer. $150 shipped, sraa
pics: Image hosting, free photo sharing & video sharing at Photobucket
Again, all prices are "or best offer" but try to be reasonable :)
Discussion Starter · #12 ·
bump
1 - 12 of 12 Posts
