181 - 200 of 3104 Posts
^^^Hey pankrok, I see you have a CX-7, any interest in some a pillars that are built to house a Hybrid L3 and L1 tweet in them? They are just sitting in a box in my garage and I'd like to get them out of the way and recoupe some of the funds spent on them. Sorry to be off topic.
[offtopic mode] thanks mate but a-pillars is the last thing I am in need now! [/offtopic mode]
Jim, that is fantastic news about the DAC from the H800 being used for iPod playback (astounding, really). Looking forward to hear if this is true for the H701, as well, and for playback of HD radio on the w910. Jim, can you clarify what the w910 + H800 will not be able to do without the RUX controller?
And so, with regard to the optical out, if HD radio gets to use the H800 dac, but perhaps no to ipod dac bypass using the w505/h701, I would really have a hard time justifying a purchase of the older gear, even it it meant saving a lot of money. The new system already seems quite a step up over the old system in so many ways, and getting to use the H800 DAC for all digital sources would be the topper, even if I had to buy the $250 RUX. Ultimately, despite that the newer system would be soooo much more money (prolly $2000 msrp for all 3 new pieces versus maybe $800-$900 or so for the w505/c701/h701), we're talking a quantum leap, here - doesn't everyone agree?
Jim, if HD radio playback means get to use the Wolfson DACs in the H800, would this be true for Satellite radio, as well? Thanks for poppin' in.
KustomKarAudio, happy 40th! ;)
The question I have now is will this sound better than my Matt Roberts modified 701? It obviously has more tweakability but will that trumph Matt's magic?
What improvement do you hear in your h701's mod? Here's what you know the H800 is going to give you:
  • More tuning ability - 10 vs 5 bands of parametric eq in main channels and 5 vs 2 bands of parametric eq in sub channel.
  • The ability to slope your crossover at 36db max vs 30db max
  • 5-10db higher signal-to-noise ratio depending on your source
Do these benefits trump your modded H701? Are there even other benefits offered by the H800? Not sure on the latter question, and only a side-by-side with your h701 might give your your answer, but seems like even a modded H701 would be hard-pressed to best the advantages the new H800 seems to offer.
Keeping the iPod straight digital all the way to the DAC was a big push for us with this guy, we're definitely happy with it.
No answer from Japan yet on the H701 doing it, but I'm pretty certain it doesn't. I just want the final answer for you.
The H800 is 100% functional on its own, without the RUX ... however, you'll need to use a PC to tune it. Once tuned, via manual or automatic over the PC, you can save up to 6 preset tunes. Once you disconnect from the PC, the presets are saved in the H800 and the W910 will be able to adjust:
1) Presets - need to be saved from the PC Software
2) Balance/Fader - pressing the "speaker" soft button on the Audio screen of the W910 will bring you to the balance fade screen
3) Sub Level
That's it without the RUX. The real intention (and it won't ring true with most here as we are crazy tweakophiles) was to give the installer/shop the ability to tune the car, set the various presets and give the customer the control he needs without the ability to change the tune, so doesn't come back and say "I didn't touch anything but my tweeters are blown...and the shop[or mfg] is stuck with the bill" or something along those lines when you give them too much control of everything.
To answer a few of the volume-related questions. We've done our best on this guy to REALLY clean up the analog side of things. The ideal situation is to run a RUX when using RCA (hi or low level) in, but the input stage will take 0.1 to 10V, so you could easily use your factory or AFT HU volume to control things. If you feel the sound is noisy (it won't be), go ahead and grab a RUX and flush it in somewhere if you're feeling crafty, but 99% of installs will not need it.
Adding the RUX gives you all the control you all know and want, so it's worth the expense really ... just to be able to tweak with things :D It really depends on your install and your OCD level.
Jim
Jim, for someone who has never tuned with a PC, do just bring your laptop inside the car and tune with the software and a mic? You then perhaps load the settings via USB, or a memory card?
Also, is the new RUX controller smaller than a single DIN and thus could be placed many different places? Maybe even above or below a double-din should space allow? It has very little physical depth to it, correct?
Two other questions, if I may:
  1. Will any of the new 2011 Alpine single-din CD or media players have optical out and be able to work with the RUX/H800 combo?
  2. Will only the iPhone control Pandora from the w910, or other new Alpine Pandora-cable units, or will one be able to stream Pandora from an Android or Blackberry device, as well?
Thanks so much, again....
Great answers from Jim! I too am curious about the Pandora functionality as I have a DroidX. I have been holding off on switching over to the iPhone, but now that Verizon has picked it up, I may make the switch unless more manufacturers start offering Android support as well.
Is Pandora streamed over Bluetoof, USB, or lineout on Alpine compatible head units?
If it's anything but USB then I would not worry about how it leaves the W910. Not that it's gonna sound bad, but bluetoof compression and the added DA/AD of line out is going to ruin the ideology of digital out to the processor.
Perhaps the thread title should be changed to be more relevant (now that we have a name for it).
I don't know about you guys, but I'm very glad we now have an Alpine rep available on the forum. :D
Perhaps JBL's Andy Wehmeyer was a good influence? ;) Let's hope other companies join in as well.
Jim, thanks once more for the input!
Hoot, good thing you waited huh? ;)
Perhaps, Rex, you are right; however... we still need to see what the w910 is going to sell for first, right?
With the w910 having built-in functionality of Bluetooth, Nav, HD radio, Satellite and Pandora (I think it has all of that built-in, or at least it has much of that built in), not to mention the built in crossovers, eq and time alignment for guys wanting an in-between prior to being able to afford the H800, the w910 still might command a hefty price.
If the w910 msrp is steep, then perhaps the w505/h701 might be a better in-between alternative for someone like myself. ;)
great input Jim!
how come not 24/96? is it too early for alpine to "follow" audison?
and I guess not a chance for using usb as audio input to the unit (carpc issue again!)
Feel it's not really polite to say things like "why didn't you do like ...(brand name)..."
Jim is kind enough to hang around and give inputs about his opinions and about what he knows.
Don't take it personally, other posters did/do that as well. Just saying... ;)
Again thanks Jim for being part of the forum.
Kelvin
If you are doing ImprintEQ, it will tell you where to place the mic, you'll place the mic and then exit the car while it chirps, beeps and tunes itself to happiness :D.
Manual tune, you'll adjust the parameters on the screen and then listen to it on the fly.
The RUX is 16mm x 161mm x 40mm and will come with a "flush cup" that will allow you to either flush or mold it in, as well as surface mount if you want.
No Optical out in the line for 2011 outside of the W910.
The W910 does not do A2DP streaming, so it will not stream BT from Android or RIM. You'd need do run an AUX-In line to the processor (or HU) to get the audio in via RCAs. Any of our other HU's with a KCA-400BT attached will stream over BT from either of those platforms.
For Music and Internet Radio, there is nothing better for you than the iphone ... I begrudgingly switched after two years of being a Droid and BB lover....it's just easier. As a phone, thats a topic for a different day, but now that Verizon has it .. its gonna pretty hard to look away from for most.
Over USB, I know for a fact that we run digital out of the iPhone to the DACs of our HU's ... I'd imagine it'd pass to the DACs in the H800, but like HD Radio .. I'm waiting on the final, final answer about where the D->A takes place.
You're all welcome. I'm happy to be here as I'm a DIYer from the start, much like a lot of us in this industry. I'm not tech support, so I can't answer random complaints and stuff, but tweako stuff like this is right up my alley :D
Subscribed. :lurk:
Excellent thread. Thank you, Jim Walter, for your input to this forum and the extraordinary access to the engineering and design behind the scenes! I may not be able to make use of it all immediately, but I *love* reading up on it. I've been waiting for a good integrated head unit / processor solution to come along...one that works well with my iPhone 4. Integrating the "easy mode" of the Imprint process with manual tweakability is exactly what I've been hoping for. One question: can you expand on the options for time alignment that are available in the H800?
Moderator
Jim, not sure if you saw this list of questions or not, so I'm quoting myself.
I also sent you a PM with a couple questions. I know you're busy, so if you don't have time to answer, I understand.
Thanks again for your input to this thread.
- Erin
Jim, thanks for dropping in.
I have a couple questions as well:
  1. Will the 800 also have graphic eq? If so, can it be used in conjunction with the parametric or will you have to choose one like the 701?
  2. Are the crossover points 1/3 octave or something else? You mentioned pc setup...do we have the luxury to manually type in desired crossover points?
  3. With the parametric, what is the bandwidth (q) adjustable from?
31 band on 5 outputs? Front, rear and Center? 10 on Sub?
