AMG C63S (s205 wagon)
17K views 65 replies 11 participants last post by  BP1Fanatic
So just got a 1 year old Merc wagon with Burmester, and kinda felt it somewhat lacking, so busted out the UMIK-1 and REW (set to front focus):
297360
Seems to have a big dip at 180 to 400Hz, not altogether surprising given the layout (although mines a wagon, assume it's the same):
297362
  • 1" Tweeter 4" Mid in each front door with shared 50w chan
  • 4" Mid in the dash with 50w chan
  • 1" Tweeter 4" Mid in each rear door with shared 50w chan
  • More 4" Mids in the rear shelf
  • Two 8" Woofers under the dash in the bulkheads
Not after doing a mega build, open to thoughts and suggestions. Have read a blog from someone else who worked with this car, and read that they set the mid to -10 (and raised an eyebrow) but can see why he did, to pull down the mids to match the dip.
Thoughts?
#5 ·
The response in your last plot (dark Blue line) should sound half way decent. Maybe a little shrill at 1KHz. What are your impressions?
BTW: That car is screaming for a full blown upgrade. The first time I have ever seen an OEM do a kick panel / foot well subwoofer solution. I'll bet you Focal Utopia M midbass, midrange, and tweeters would nearly be drop in replacements. And with your 3D modeling skills making the adapters you'll need would be easy.
Common, you modified your 911. You need to do your daily driver 😈.
#4 ·
So I have found B-2 M-7 T-0 remove the 1k 'telephone voice' effect.
Decided to try the new focal drop in kit, otherwise it was a very slippery slope into MOST150-to-SPDIF + DSP + AMPs + ESOTAR 3 way + god knows
It looks to be pretty linear to 100hz, but lets see how they perform vs the stock generic german 'premium' drivers
297390
#6 ·
Yeah the 1k 'old telephone' style vocals sounds artificial, especially with so much missing 150-450.
I'll start with the focals, they do a drop in sub but I don't think it needs that; rather a mid-bass in the floorwell and a proper sub in the boot.
I'll document the progress tho
#8 ·
Ha yes
Going to see what difference the Focals make, if if they fill in that mid bass dip then I'll just look at the bottom end like so:
Front-Bass feed into a high level (non DSP) amp with x-overs so I can HP the front bass and LP to a 10" in the boot.
#11 ·
So I did think about stealing the Mosconi from the 911 however given any processing will have an inherent delay (expected 5ms) it means you shouldn't (in my humble opinion) mix the OE amp chans and say a DSP powered amp. Really it's then about going all in; MOST150 gateway feeding a DSP & amp combo.
Baby steps, let's see what the Focal drop in kit brings. I'm unconvinced about the sub in floor, but would see it as a very nice midbass, some have put a upside-down MW172 in that location with success.
Just a nugget of nostalgia. I've been using your Avatar pic as the lock screen avatar on my work computer for about 10 years. I adopted it after the 1st time I visited Japan on business. How about them apples?
So when google tried to weigh into the social media space and force me to have a google plus user account, I wanted to make mine anonymous and chose this as a random smiley that fit in their round avatar space. Since then forums let us log in using google auth, so it's kinda followed me here :D
#10 ·
#13 ·
So Focal's in across the front now, a more open sound and certainly less harsh. Certainly better, and some work with the EQ I suspect has helped, but bass is still flabby with that acoustically loaded boom.
So the component speakers came with a cross over which looked to just be 2 caps for the tweeter, however there was also an inline large cap for the woofer too between the crossover and the mid.
297882
Black = baseline system with no EQ
Green = Focal 'inside' MBZ components and centre
Blue = As above but tweaked the EQ to -6 -6 -6 which had the net result of pulling that 200-400 up
#15 ·
So scope creep..... idle thoughts are:
  • Focal Centre
  • Focal Components (passive xover to tweeter)
  • Factory subs converted to mid-bass using adapter with 6.5" MW162GT
  • Rear doors left alone
  • C Pillar drivers unused
  • NAV TV to get clean faded optical signal from MOST150
  • Helix V eight running as per diagram
  • Sub amp
  • 10" in a stealthbox
Difference between this car and my 911 is that it's a family wagon, so needs a '2 seat' tune and rear seats need some love too. The helix looks amazing for this use case, with real-centre to drive the centre chan and enough IO for all the other speakers and chan 9&10 for the sub.
#16 ·
  • Focal Centre
  • Sub amp
I knew you would give in :). Do yourself a favor and buy the V Twelve. This will give you the ability to go fully active in the future with just a slightly larger amplifier.
#21 ·
Meh... Skip the MD142 and go straight for the E430. It would probably fit nicely behind that Burm grill. I'd like to see what's behind that A-pillar grill too. You should be able to mount the MD102 behind it.
#24 ·
I've only used the Focal Utopia M so can't comment on the Flax. If the Flax are anything like the 3.5wm then they will require in car tuning. Provide a flat frequency response and they sound sweet. Leave any peaks in the response they will bite (sound harsh). They over accentuate flaws in frequency response.
#25 ·
Ok that's golden advice, I'll get on with my helix order. They could be good, but need taming.
First run out I was like DAFUQ but they've warmed a little, but I suspect the burmester EQ is trying to put glitter on factory turd speakers.
#30 ·
So I'm thinking optical feed for the front channels, but use a analogue input for the rears to retain the fader but more importantly the rear parking sensors. However I don't really want a nest unused loom and connectors barrelled between the Zen and the Helix which will be back to back, so I'm going to make my own custom loom between the two.
So while updating the firmware to the latest, I set about finding new connectors on RS:
300192
It's a Molex, Micro-Fit 3.0 Female Connector Housing, 3mm Pitch, 24 Way, 2 Row
RS Stock no.:511-1004
300193
Connectors and pins ordered, see what I can make up.
