Amp: older Hionics zues xi
Head unit: Apline x7hd
My amp cuts out then turns on a few minutes later. This happens most (if not only) when i turn the subwoofer volume on the head unit up. The head unit subwoofer rca output is pretty weak, so I want to be able to turn this up. I installed a line driver today, jumping the remote wire from the amp to the line driver. and both devices cut out and turn on at the same time. Note that the amp cut out before the line driver was installed. Could I need a relay to fix the problem? To get a stronger more constant remote?
The amp does not go into protective mode, just cuts out and the green power light fades away.
I also jumped the power wire from the amp to the line driver, fused of course.
Now thinking about it, the amp has cut out with the head unit sub volume all the way down
Thanks for any input,
Joe
Joe
