1 - 10 of 10 Posts
I'm looking for input from someone familiar with the internals of typical class D amps.
I have an amp that is taking the speaker-level input from an OEM head unit. What I want to do is tap into line-level inputs in that amp before amplification, run it through a miniDSP, then send the signal back to the amp for amplification. The amp has a speaker-level-to-line-level converter, and RCA line-level outputs.
HU >> Amp internal line level converter >> MiniDSP >> Amplification circuit >> speakers
Has anyone tried hacking an amp like this?
(yes... I know I could replace the HU, buy a separate line-level converter, or get an OEM integration unit instead of hacking around with amp internals)
probably need to find a schematic and pull it from before the amplification section. Then you'll have to hard cut the amp and destroy its standalone abilities and then resplice your minidsp into it.
Yeah, you will need a service manual and some soldering skills. Hope that the speaker-level to line-level portion of the circuit is an exposed separate trace in the amp, and not buried in a chip somewhere...
What amp do you have? Maybe we can help find a service manual.
Save yourself the hassle and buy the balanced input mini dsp. Switch it to 2V input, build a 3:1 voltage divider with some 1/4 watt resistors you can buy at radio shack and send the speaker level output of the radio directly into the Mini DSP.
I think he wanted to "re-use" the amplifier portion of the amp though......
UN-realated: Andy, are you at CES?
I support this; it is simpler and does not require you tearing into your amp. Much cleaner solution.
Thanks Andy -- great idea.
For those who wondered about the available inputs on the experiment amp, there is a single set of RCA plug inputs that will take either line-level or speaker level inputs.
1 - 10 of 10 Posts
