Hey guys just wanted some opinions from the forum as I trust the advice from this forum over any other audio source anymore.
I have both the amplifiers listed in the title, the Skar LP-80.4ABV2 & Wolfram C-90.4. Both 4 channel, Skar obviously does 80x4 @4ohms and the Wolfram 90x4 @4ohms so power is a wash. I will ultimately end up using both in my install but am trying to decide in what way. One amp will power my front stage (SB Acoustics SB17NRXC35 6.5s and Tang Band 25-2176 Tweeters) and the other will run my rear coaxials (I need rear fill for passengers) and midrange (Dayton RS75-4) if I decide to run a 3 way front stage. For starters it will just be the 2 way active front stage. Amps get their signal from my Dayton Audio DSP-408.
So I'm just looking for opinions on what amp to use on the front stage, essentially which 1 would you guys personally prefer or think is a better amp? The Skar is a class A/B where the Wolfram is class D.
Thanks
Sent from my SM-N950U using Tapatalk
Thanks
