1 - 20 of 28 Posts
Well im finishing off my celica build has made me crazy! I cant decide who makes a solid amp thats 2500x1 @ 2 ohms. I cant decide between Rockford Fosgate t40001bd, Orion HCCA-50001, and possibly ARC SE 4000. Ive been to lots of forums and there's lots of information but no consensus. Can someone make a sugestion.
Soundmagus X3200
3000w RMS @ 2 ohms
14.8" x 9" x 4.2"
This is the amp I was going to buy when I wanted 1500 watts @ 4 ohms. It's two amps stacked in a common heat sink, so the footprint is extremely small for the power. This company does a lot of OEM work, and the same amp is sold in the US but not in the stacked form.
You have to order it as a sample direct from the distributor, but it can be had for a small fraction of your budget.
Well they are all different wattages
The JBL is HUGE and I MEAN HUGE
Zapco is 2200
JBL is 3000
Arc is 4000
All differnt watts, so just choose one that matches your subs
Zapco is smallest and has tons of balls, considered by most and even me to be the best sub amp.
All the amps you mentioned are great amps, cant go wrong with any of them
Best sounding of all of them would be the ARC 4000 SE as it is Class A/B output section, second would be the Zapco 9.0. If SQ has any priority I would suggest you stick with these two or options for a single amplifier solution.
Eric
1 - 20 of 28 Posts
