Hey all, I’m in the market for a new sub amp for my 2 alpine S-W10D2’s. I’m running them at 2ohm currently on a taramps bass 800 2ohm amp. Problem is I don’t think this specific taramps amp is actually putting out what it’s rated for. If I don’t use sound retriever, loudness setting and turn up the sub level output on my hu it doesn’t hit hardly at all. Before anyone ask if it’s tuned, yes it’s tuned and I normally wouldn’t use any of those settings on my hu. I don’t need to use those settings because I’m also running a 4 channel amp for my tweeters and doors. I’ve been running this amp for over a year and when I first installed it, it just didn’t sound like it had the power output it’s rated for.
I’m looking for a d class mono block somewhere between 800-1000 rms at 2 ohm. Something that will run cool as well because it’s on the back wall in my truck. I’m leaning towards the kenwood 9106d, but I’ve also heard good things about hifonics. I’d like to be around $250. I’ve also thought about Skar but heard they run hot and a lot of people are saying they are not great. I’ve had good luck with kenwood in the past but they run hot. But my last kenwood was a a/b class not a d. Anyone use ct sounds? Thanks for the input everyone.
Forgot to add my sub specs. The subs are 600 rms a piece. I’m running these subs because of their low sealed air space requirements and shallower mounting depth. They are in a .60 per chamber sealed box. I know when you add in woofer displacement the box may be on the small side but that’s all I have to work with.
