1 - 10 of 10 Posts
System is Hertz Mille components front/rear all running active and a yet to be determined 12" sub. DSP is Helix DSP Pro MKII being fed via fiber from head unit. Other than Audison, are there any other amplifiers that will accept a digital input. I will probably need 3 amps (front/rear/sub daisy-chained) with the sub amp outputting at least 500 watts.
Thank you in advance.
They also have built-in DSP... which negates the use of his DSP-Pro MkII.
With that said; they are fabulous amplifiers. Worth looking at.
Can he get a processed digital signal OUT of his Helix? I don't know much about the Helix stuff, but after a quick look it's only analog out.
YellowC4S, are you planning to ditch the Helix in favor of amps with digital input and DSP?
the helix dsps don't have digital outputs.
brax matrix amps have digital inputs, but at this point they're pretty much useless.
Why are they useless?
I am going to use mine for a source using a DAP directly to my nox4dsp.
That makes more sense to me, now.
1 - 10 of 10 Posts
