Hey guys, I'm selling-off some gear I'm not using. Everything has been bench tested with a power supply and works as it should. I will video any of these powered up playing music upon DM request.
ITEM BRAND & MODEL #: Arc Audio KS600.2v3 2-channel class G/H powerhouse (1200w bridged to 4ohm)
Audio equipment Gadget Font Ac adapter Electronic device
Circuit component Electronic component Electronic engineering Audio equipment Computer hardware
Audio equipment Electronic component Electronic instrument Electronic engineering Computer hardware
CONDITION: Used - 9/10 a few small imperfections otherwise appears and opperates as new
PRICE: $665 $650 USD (shipping and fees included)
SHIPPING: Included
ADDITIONAL INFORMATION:
2-Channels @ 4 Ohms 400 Watts
2-Channels @ 2 Ohms 600 Watts
1-Channel @ 4 Ohms (Bridged) 1200 Watts
Frequency Response 5Hz - 50kHz
Crossover Range 55Hz - 5500Hz
Bass Boost 15dB @ 45Hz
S/N Ratio CEA2006 @ 1W95.1dB
S/N Ratio @ Full Power112.0dB
Input Sensitivity (Low) 200mV - 3.5V
Max Current Draw 120A @ 1200 Watts 1% THD
Idle Current 1.14 Amp
Fuse 4 x 30 Amp
Dimensions 15.5"(L) x 8.0"(W) x 2.375"(H)
ITEM BRAND & MODEL #: Helix SPXL 1000 Competition monoblock class D
Rectangle Audio equipment Material property Box Gas
Musical instrument accessory Audio equipment Electronic component Cable Gadget
Circuit component Passive circuit component Electronic component Hardware programmer Audio equipment
CONDITION: Used - 8/10 A few scuffs, not perfect, but it is a very good amplifier, never gets hot even when running 2ohm loads. I installed a new, quieter, higher flowing fan.
PRICE: $475 USD (shipping and fees included)
SHIPPING: Included. Will be shipped in original Helix wood crate.
  • 750 watts RMS x 1 at 4 ohms (1200 watts RMS x 1 at 2 ohms)
  • 1750 watts RMS x 1 at 1 ohm
  • Class D design
  • 24-karat gold-plated RCA input, power, and speaker connections
  • double-sided copper plated circuit boards
  • noise-free inputs
  • stereo or mono inputs with Real Mixed Input option
  • can be ganged with a second SPXL1000B for double the power
  • variable low-pass filter (35-250 Hz)
  • bass boost (0-18 dB from 40-120 Hz )
  • continuous phase adjustment: 0 to 180 degrees
  • wired remote bass level control included
  • preamp inputs and outputs
  • 2- or 4-gauge power and ground leads and a 150- to 160-amp fuse recommended — wiring and hardware not included with amplifier
  • fuse rating: 80A x 2
  • 20"W x 2-1/4"H x 10-15/16"D
** SOLD ** ITEM BRAND & MODEL #: Rockford Fosgate Power T400-4 4 channel a/b
Cosmetics Rectangle Material property Box Font
Audio equipment Font Gas Electronic component Multimedia
Musical instrument Keyboard Musical instrument accessory Electronic instrument Audio equipment
CONDITION: Used - 6/10 This one isn't great cosmetically, but its a very solid a/b amp and it performs just as it should. Would be a great mid/tweet amp for a budget build at a great price.
PRICE: $180 USD (shipping and fees included)
SHIPPING: Included
  • 60 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
  • 200 watts RMS x 2 bridged output at 4 ohms (2-ohm stable in bridged mode)
  • Dynamic Thermal Management cooling system
  • Differential Input circuitry eliminates hum
  • variable high- and low-pass filters (50-500 Hz, 24 dB/octave)
  • variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12k Hz)
  • optional remote bass/treble boost (available soon)
  • Class-AB amplifier design
  • MOSFET power and output stages
  • 4-gauge power and ground leads and a 100-amp fuse recommended
  • 13-5/8"W x 2-1/4"H x 9-5/8"D
** SOLD ** ITEM BRAND & MODEL #: JL XD600/1v2 monoblock ** SOLD **
Handwriting Circuit component Font Audio equipment Gas
CONDITION: Used - 7/10
would be an 8 or 9 but I don't have the cover panel or bass knob for this.
PRICE: $200 USD (shipping and fees included)
SHIPPING: Included
  • RMS Power Rating @14.4V:
    • 4 ohms: 400 watts x 1 chan
    • 3 ohms: 500 watts x 1 chan
    • 2 ohms: 600 watts x 1 chan
  • RMS Power Rating @12.5V:
    • 4 ohms: 300 watts x 1 chan
    • 3 ohms: 400 watts x 1 chan
    • 2 ohms: 500 watts x 1 chan
  • Low level: 800mV - 8V input sensitivity
  • High level: 200mV - 2V input sensitivity
  • Frequency Response: 7 - 500 Hz
  • Total Harmonic Distortion (THD): <1%
  • Signal to Noise Ratio: >87 dB
  • Damping Factor @4ohms: >1000 / 50 Hz
  • Selectable Infrasonic Filter: Off / 30 Hz
  • Selectable Low-Pass Filter Slope: 12 dB or 24 dB
  • Variable low-pass filter: 50 - 500 Hz, 12 or 24 dB/octave
  • Fuse Rating: 50A x 1 inline (not supplied)
  • Dimensions: 7.09"W x 8.52"L x 2.05"H
