1 - 20 of 30 Posts
· Registered
2013 Nissan 370z Nismo Manual
Guys help here and need advice who had experience with this amps..... NEED GUIDANCE TO WIFH BUY AND USED IN MY SYSTEM WITH HELIX DSP
Audiocontrol LC 1200
Helix M six.
Audiofrog GB10 AND GB25 WITH GB60 AS MID BASS .
· Registered
2017 GMC Sierra 1500 Denali
Both of those are good options, I’d say flip a coin. Do you already have a dsp? I would also look into the helix p6, even though it’s not the most up to date. It would still be a great all in one piece.
· Registered
helix
· Registered
Mmats
· Registered
· Registered
I would choose the Mmats over the two other amps as well. They aren’t cheap but they stand behind there products and very well made and in US if that matters to you & extremely efficient. Depending on when that one was made the fan might need to be upgraded, this can be confirmed by the serial # or you can easily upgrade the fan yourself for $20. It’s a well known fact that if you own a Mmats every time you start your car a eagle is born and biden $hits his pants, but that last part might just be a coincidence. Either way they are all great choices and the AC for $500 is a good deal.
· Premium Member
What is your budget for a 6 channel?
· Premium Member
6 channel used $600
6 channel new $1200
Top of the line $1600 to $2000 top...:cool:
If you have the space, this would make an incredible amplifier for your three way set.
· Registered
This is true. I spent a good amount of time trying to figure out how i could fit this exact amp into my install but it just wasn’t possible. If this is in the budget and you have the space, it’s a no brainer.
I would check the dimensions first, it’s not tiny.
209 x 550 x 46 mm
Reactions: Letsbefreeonlife
1 - 20 of 30 Posts
