1 - 20 of 51 Posts
Another "Baby on the Way" Sale! Arc Amps, Eclipse Al 12...
Baby is on the way, so all the goodies for my old “baby” gotta go… Thank you for looking and please pm any questions.
Ebay account under same user name – 100 transactions with perfect feedback both buying and selling
iTrader rating of 100%, all buying
I always ship items as I would want to receive them. Thanks for looking!
Paypal preferred
Arc FD1200.1 – used - $300 Shipped
Bought this display amp and had in the vehicle for maybe a month before pulling out to dynamat and luxury line. Never made it through the project, so this amp has been sitting in the closet for some time. Looks beautiful and works perfect. produced great sound when paired to my eclipse AL. Please note, the power-in terminal does have a crack. I received the amp this way, and have to assume it is due to an overzealous screw down. Not very noticeable, and if the end-caps are used it will never be seen. Did not have any effect on the performance. There are also two very small discolorations in the black finish. Includes box and remote bass control.
$630 @ Woofersect
Nada on ebay
  • Monoblock Amplifier
  • RMS Power Rating:
  • 4 ohms: 510 watts x 1 chan.
  • 2 ohms: 1010 watts x 1 chan.
  • 1 ohm: 1100 watts x 1 chan.
  • Slave Input and Output
  • Speaker Level Input
  • Fan Cooled
  • Concealed Connections and Controls
  • 0 - 18 dB Variable Bass Boost Remote Control
  • Variable Subsonic Filter
  • 24 dB per Octave Low Pass Crossover
  • Frequency Response: 20 - 250 Hz
  • 4 Gauge Power/Ground Leads
  • Dimensions: 21-3/4"L x 10-3/8"W x 2-3/8"H
Arc FD4100 – New - $250 Shipped
Bought NIB and never saw power, was planning to couple this to cdt es components, and a little bummed that it will not happen at this time. Have box, end caps, and all the goodies that came in the box when I received it.
$329 on Ebay
$430 on Woofersect
  • Independant front and rear 12dB stereo crossover 55Hz to 5.5KHz
  • Seperate front and rear high/low/full range select switch
  • 4 channel/2 channel or 2 channel with bass select
  • Seperate front and rear mono/stereo/bridged select feature
  • 18dB bass control at 45Hz select feature
  • Protection against: reverse voltage, over voltage, speaker short, and thermal overload
  • Heavy duty construction
  • Output power: 50x4 @4 ohms, 90x4 @2 ohms, & 180x2 @4 ohms bridged
  • Transient distortion: <0.1% @4ohms
  • Frequency response: 20Hz-20Khz
  • S/N ratio (A wtg): >95dB
  • Bass boost: [email protected]
  • Input sensitivity: 250mV - 2.5V
  • Crossover: 55Hz variable 12dB
  • Fuse: 40A x1
  • Dimensions: 10 3/8" x 17 3/4" x 2 3/8"
Hifonics Europa XI (2001)– used - $125 Shipped
Original owner of this nice amp. Great condition, only used for a few months b/f the altima lost a fight with a tree. = (
I've had this boxed up and sitting for too long and have moved on to different projects. I held on to it b/c I do really like this amp. It was run bridged to psd-216 comps and there was no need to push it.
To me, it sounded great pushing the quarts and made plenty of good power, but did get hot after extended use.
Includes original box, manual, and boost control
50 watts x 4 channels into 4 Ohms (stereo)
100 watts x 4 channels into 2 Ohms (stereo)
150 watts x 4 into 1 Ohm (stereo)
200 watts x 2 channels into 4 Ohms (bridged)
  • 300 watts x 2 channels into 2 Ohms (bridged)
  • Additional Features
  • Full Mosfet operation
  • Stiffly Regulated Power Supply
  • 4,2 and 1 Ohm Stability
  • 0 to 18 dB variable Bass EQ
  • Fully Variable high/low pass/band pass crossover network
  • Variable Subsonic Filtration on 2 Channel amplifiers
  • Class AB Operation
  • Balanced Line Driver Inputs - .4 to 18V input Sensitivity
  • Gold Plated RCA Lineouts for maximum versatility
  • Fan Cooled Operation (Boltar, Zeus and Colossus)
  • Comprehensive On-Board Diagnostics
  • Wrap Around Brushed Extruded CAD aluminum Heat Sink design for superior heat dissipation
  • Discreet Transistor low level circuitry
  • .2volt to 9 volt variable Input Gain Control
  • Visual Diagnostic LEDs
  • Thermal overload, speaker short and clipping overload protection devices
  • Gold Plated Molded Terminal Block Configuration
Will add to this post later with the following:
12” Eclipse AL – old school SW8122 DVC - small ding, but plays perfect
Clarion hx-d10 deck – two
Quart PDS 216 (old school Germany built) - box and all hardware including unused template.
Thanks again, all!
Best,
J
Discussion Starter #2 (Edited)
Eclipse SW88120 DVC - $145 shipped OBO
There is a small scuff on the surround and cut small cut in the gasket. Play perfect. I've owned this since 2002, and it had play duty in my Altima, then briefly in the civic. I have only used this sub sealed. Love the sound
I paid $200 + shipping back then, and have not been able to find any recent sales of one online, so I'll ask $145 shipped/insured... Thank you!
Can't do trades, my friend, but pm sent your way. Thank you!
Pm'd and corrected sub descrip from 88122 to 88120
Thanks guys!
old school mbq made by zee germans. comes with everything and in great shape! only a few scratches on the crossover covers and a bit of fading on one tweeter grill. bought these new, and used in my altima for maybe 6 mnths - $150 shipped
Lunch browsing bumpage - OBO on all items!!
Combine shipping on the amps if bought together... or just buy it all! :D
These items make for quite a niiiiice sounding system, all ready to go
Discussion Starter #12
I used 4, I'll check if it fits 1/0 when I get home. Thanks again!
Discussion Starter #16
Happy Monday Bump.... ugh.... when are they gonna move the superbowl to a Saturday?
ARC 1200.1 - $280 Shipped
ARC 4100 - $225 Shipped
Europa XI - $115 Shipped
Eclipse SW88120 - $135 shipped
MBQ PSD-216 Comp Set - $135 Shipped
Discussion Starter #20
Hifonics pending...
Plenty of good stuff left. Going to be testing two hx-d10 decks to put up soon!
Hope everyone is having a great weekend!
1 - 20 of 51 Posts
