1 - 2 of 2 Posts
I'm having trouble figuring out exactly how to wire up my two subs. Heres the set up...Dual 4ohm xtr pro orion 12's in a sealed box going to a Directed 1100d. The directed is a mono amp that is 1ohm stable and I plan on running it at that impendence, however my confusion arises in that the amp has two sets of inputs that are paralleled internally. I am running each sub in series and running them to the amp as if it was a two channel amp, however one sub isnt working. Should I run things as diagramed in this picture? If I did it as per the diagram, wouldnt wiring this way goes against the internally paralleling of the amp? Info on wiring the amp is on page 6 of the link posted below.
http://www.directeddealers.com/manuals/og/directed_audio/G45014.pdf
1 - 2 of 2 Posts
